Sol from the 5th of April 2021.
eroel
Been thanked: 1339 times
Post by eroel »
Hi:
Did some shots before lunch, the seeing was regular, but the wind was strong and soon got clouded.
Thanks for looking a few processed.
Best regards to all.
Sol del 5 de abril del 2021-Meade-CaK-PSTmod-1pos.jpg (866.81 KiB) Viewed 124 times
Sol del 5 de abril del 2021-Meade-CaK-PSTmod-1neg-pos.jpg (963.8 KiB) Viewed 124 times
Sol del 5 de abril del 2021-Meade-CaK-PSTmod-1pos-neg.jpg (891.67 KiB) Viewed 124 times
Sol del 5 de abril del 2021-Solarmax 90-DS-BF30-1pos.jpg (947.83 KiB) Viewed 124 times
Sol del 5 de abril del 2021-Solarmax 90-DS-BF30-1neg-pos.jpg (1.13 MiB) Viewed 124 times
Sol del 5 de abril del 2021-Solarmax 90-DS-BF30-1pos-neg.jpg (968.61 KiB) Viewed 124 times
Sol del 5 de abril del 2021-Stellarvue-Daystar-1pos.jpg (1.84 MiB) Viewed 124 times
Sol del 5 de abril del 2021-Stellarvue-Daystar-1neg.jpg (1.86 MiB) Viewed 124 times
dhkaiser
Has thanked: 907 times
Been thanked: 747 times
Re: Sol from the 5th of April 2021.
Post by dhkaiser »
Excellent, well done Eric.
Dan
Lunt LS60THa, Lunt LS60FHa DS
Lunt 102mm ED, William Optics ZS73, Herschel Wedge
Celestron C6 SCT
Ioptron AZ Pro mount, CG-4 mount
ASI 178 mono
South central Indiana
USA
Has thanked: 2696 times
Been thanked: 2363 times
Post by DeepSolar64 »
Nice work! 👍🏻
Stardust5858
Has thanked: 312 times
Been thanked: 379 times
Post by Stardust5858 »
Lovely captures Eric, thanks for sharing. Just a question, Re: the Ca-k images with proms. Are the proms taken in ha and added or are they images in Ca-k as I've seen them too in Ca-k on the 4th and 5th?
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Nec6 Eq Mount.
Has thanked: 1682 times
Been thanked: 1523 times
Post by Carbon60 »
Very nice, Eric.
Lovely images. Your Ca K images, with proms, are always very impressive.
Has thanked: 3769 times
Been thanked: 1497 times
Superb Eric :bow :hamster: the large prom has really changed in shape during the day.
Has thanked: 1262 times
Been thanked: 685 times
Post by ffellah »
A beautiful set Eric
EGRAY_OBSERVATORY
Been thanked: 1675 times
Post by EGRAY_OBSERVATORY »
Thanks vm Eric for sharing some excellent images and processing. Can't get much sharper than yours..
Regards
terry
eroel
Post by eroel »
Nigella, Alexandra, Dan, James, Stu, Franco and Terry:
Much appreciated comments, thanks for looking.
Nigella, the "proms" and "surface" CaK shots were taken with the same scope, it is a Meade 102mm f/9 refractor fitted with a CaK PSTmod that I made.
As for the FD Ha shots, they were taken with a Solarmax 90-DS with a BF30, the higher resolution ones were taken with a 102mm f/7 Stellarvue refractor fitted with a 4X Baader Telecentric and an old Daystar T scanner filter.
Here is the "prom" CaK FD as it comes out from AS!3 after aligning and stacking, then I do some processing and resizing it so that the "surface" one fits correctly in the "prom" one.
After that when the composite is done, I do some final processing, (deconvolution, and levels with the lasso tool).
As you can see, I record the CaK prom FD´s overexposing a little bit, so to get the proms brighter, then using the lasso tool I separate the proms from the background so to make it darker with levels so the proms show clearer and contrasty on a dark background.
Sol del 5 de abril del 2021-Meade-CaK-PSTmod-1pp-P.jpg (593.64 KiB) Viewed 73 times
Has thanked: 4060 times
Been thanked: 1781 times
Very good indeed Eric! I seem to have missed this post, the proms came out well in CAK.
eroel
Post by eroel »
Mark:
Thanks for commenting, here are the last 2 Ha shots, it was getting cloudy so had to stop the session.
Sol del 5 de abril del 2021-Stellarvue-Daystar-2pos.jpg (1.2 MiB) Viewed 59 times
Sol del 5 de abril del 2021-Stellarvue-Daystar-3pos.jpg (1.13 MiB) Viewed 59 times
rsfoto
Has thanked: 2533 times
Been thanked: 1903 times
Post by rsfoto »
Hola Eric,
Well done. Prominence looks the same as in my images :mrgreen:
MAURITS
Has thanked: 151 times
Been thanked: 343 times
Post by MAURITS »
Very nice Eric.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
