6th April 2021 Ca-K line
- Stardust5858
- Has thanked: 312 times
- Been thanked: 379 times
Hi all, still getting to grips with the new Lunt b1800 module. Only had chance with the Ca-K line today as to many fast moving clouds, so no HA today.
Still some amazing proms in Ca-K line. 70mm scope stopped down to 60mm with aperture mask from the 80ed. Processed with autostakker3, ImPPG and Photoshop. Still a lot of learning re: capture and light levels but here is the results from today.
- 20210406-135416ellabryant-cak-FDproms-col.png (2.92 MiB) Viewed 194 times
- 20210406-135416ellabryant-cak-FDproms.png (1.02 MiB) Viewed 194 times
- 20210406-135644ellabryant-cakprom-col.png (796.65 KiB) Viewed 194 times
- 20210406-135644ellabryant-cakprom.png (329.88 KiB) Viewed 194 times
- 20210406-134944ellabryant-cak-col.png (5.06 MiB) Viewed 194 times
- 20210406-134944ellabryant-cak.png (2.72 MiB) Viewed 194 times
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Nec6 Eq Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Nec6 Eq Mount.
- Been thanked: 1675 times
Re: 6th April 2021 Ca-K line
Cracking close-up Prom images in CaK Nigella. Those two I think are the best two I've yet seen.
The coloured one of those two is excellent-colouring and the first coloured disk image is fabulous in its' colour.
You've set a bench-mark for me to challenge in Cak imaging...
Well done and thanks for sharing
- Has thanked: 1682 times
- Been thanked: 1523 times
Nice calcium proms, Nigella.
- Stardust5858
Thanks Terry, appreciated. I've heard you could see proms in cak. Most days using the filter I've been able to see them. So different than in ha, as is expected. I actually love the cak filter, lol.EGRAY_OBSERVATORY wrote: ↑Tue Apr 06, 2021 7:21 pm Cracking close-up Prom images in CaK Nigella. Those two I think are the best two I've yet seen.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Nec6 Eq Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Nec6 Eq Mount.
- Stardust5858
Thanks Stu, appreciated. It's unexpected to capture proms in cak despite reading one can.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Nec6 Eq Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Nec6 Eq Mount.
- Martin_S
- Has thanked: 144 times
- Been thanked: 483 times
Great captures Nigella, Cak will be my next step in Solar imaging, your images have inspired me even more.
It's interesting to see the taller prom in the distance behind the bright Hedgerow prom.
Martin
Martin
H - alpha setup
Lunt LS60THa Tilt-Tuned Solar Telescope, LS50FHa solar filter front-mounted Double stack etalon. 2 x Barlow
Remote etalon and focusing control's ASI290mm Camera
White Light setup
Skywatcher ED72 ,100 f/10 Achromat Homemade solar wedge, IR cut filter, #58 green filter.
AZEQ5 Pro mount.
Darkside setup
Skywatcher ED72AZGTi mount , GSO RC6. Celestron Evolution mount
White Light setup
AZEQ5 Pro mount.
Darkside setup
- Stardust5858
Thanks Martin, appreciated. Yeah, it's an interesting prom in Cak, I think almost phosphorescent.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Nec6 Eq Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Nec6 Eq Mount.
- Has thanked: 4060 times
- Been thanked: 1781 times
Great shots with the new CaK filter Nigella!
Thanks Nigella. It was only recently that I discovered with my CaK scope that adjusting the brightness and contrast in processing, that I could see prominences, so make an interesting comparison with Ha, where adjusting the Etalon allows for Prominences, surface-detail or both to be captured..
- Stardust5858
Thanks Mark, appreciated.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Nec6 Eq Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Nec6 Eq Mount.
- Stardust5858
Yes, it's nice to be able to compare now between ha and cak.EGRAY_OBSERVATORY wrote: ↑Tue Apr 06, 2021 8:49 pm Thanks Nigella. It was only recently that I discovered with my CaK scope that adjusting the brightness and contrast in processing, that I could see prominences, so make an interesting comparison with Ha, where adjusting the Etalon allows for Prominences, surface-detail or both to be captured..
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Nec6 Eq Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Nec6 Eq Mount.
- Has thanked: 165 times
- Been thanked: 82 times
- Been thanked: 1339 times
Nigella:
Very good CaK images including the proms.
BTW, I did answer your question in thelast thread where I did put some FD´s with CaK proms.
Hope it helps, if you have more questions that I can answer please let me know.
Best regards.
Best regards.
- Stardust5858
Thanks Eric, I did read it. I'll have to get my head around doing the same.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Nec6 Eq Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Nec6 Eq Mount.
- Stardust5858
Thanks, appreciated.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Nec6 Eq Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Nec6 Eq Mount.
- Has thanked: 2696 times
- Been thanked: 2363 times
Very nice Nigella. I aspire to follow you into CaK imaging.
- Stardust5858
Thanks James, appreciated. It's definitely a new learning curve. I was fortunate enough to get one on sale, cheaper than the b1200 which is crazy.DeepSolar64 wrote: ↑Wed Apr 07, 2021 12:00 am Very nice Nigella. I aspire to follow you into CaK imaging.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Nec6 Eq Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Nec6 Eq Mount.
- Has thanked: 151 times
- Been thanked: 343 times
- Stardust5858
Thanks Maurits, appreciated. Yes, I was quite surprised really in cak.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Nec6 Eq Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Nec6 Eq Mount.
- Has thanked: 3769 times
- Been thanked: 1497 times
Wow! well done Nigella
those proms are amazing
I struggle with CaK proms, you make it look so easy
I'll have to try again
- krakatoa1883
- Has thanked: 110 times
- Been thanked: 364 times
Great images, Nigella, lovely colour!
Raf
- Stardust5858
Thanks Alexandra, appreciate your comments. They are definitely interesting in CaK as well. Worth a try again Alexandra.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Nec6 Eq Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Nec6 Eq Mount.
- Stardust5858
Thanks Raf, appreciate your comment. I'm pleased so far figuring out the way to acquire and process the CaK wavelength.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Nec6 Eq Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Nec6 Eq Mount.
