07 April
MAURITS
Has thanked: 149 times
Been thanked: 338 times
07 April
Post by MAURITS »
Between the clouds and and in very bad conditions.
ASI 174MM without reducer with Interference Eliminator.
Quark Chromosphere
150 mm scope.
As you can seen on the sad Quality Graph, this is the result , not really sharp, but presentable.
2021-04-07-1121 Gray.jpg (515.55 KiB) Viewed 125 times
2021-04-07-1121 Color.jpg (626.3 KiB) Viewed 125 times
Quality Graph.jpg (106.57 KiB) Viewed 125 times
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
EGRAY_OBSERVATORY
Been thanked: 1653 times
Re: 07 April
Post by EGRAY_OBSERVATORY »
Hi Maurits, considering the conditions you have produced a presentable image of quite a tall prom - so well done.
Thanks vm for sharing
Has thanked: 4057 times
Been thanked: 1780 times
Re: 07 April
That's a good image given the conditions Maurits, the quality graph looked exactly the same as those with my CaK closeups yesterday. Try dropping the laplace value down from 6 to 4, you might find improves the final stack. If you want to save a little time stacking turn improved tracking off too, though looks like you have lots of RAM on that pc so likely not an issue.
MAURITS
Re: 07 April
Post by MAURITS »
Thanks Terry and Mark for the comments and tips.
Maurits
rsfoto
Has thanked: 2509 times
Been thanked: 1890 times
Re: 07 April
Post by rsfoto »
Hi Maurits,
Well done. The weather is not always our friend.
Has thanked: 2654 times
Been thanked: 2347 times
Re: 07 April
Post by DeepSolar64 »
Looks good!!
Stardust5858
Has thanked: 307 times
Been thanked: 365 times
Re: 07 April
Post by Stardust5858 »
Looks nice Maurits despite the seeing. Thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Nec6 Eq Mount.
Has thanked: 3734 times
Been thanked: 1492 times
Re: 07 April
Magnificent images Maurits :bow :hamster:
MAURITS
Re: 07 April
Post by MAURITS »
Thanks all for the nice comments.
Maurits
Has thanked: 1247 times
Been thanked: 677 times
Re: 07 April
Post by ffellah »
You can see the bad conditions but you still got a nice image, Maurits.
