Sunny but poor seeing, some activity to see, the prominence on the south is moving about. My animation is 7.5 minutes and something is just about visible!
Robert
LS60 DS
0410 by Robert Arnold, on Flickr
0410 2021-04-10-1110_1-U-L_l4_ap535 by Robert Arnold, on Flickr
10th April
- robert
- Has thanked: 4 times
- Been thanked: 1274 times
10th April
- Been thanked: 8791 times
Re: 10th April
That's a lovely little animation and superb full disc Robert I remember you getting Newton's rings once, how did you sort that out?
- Been thanked: 16694 times
Re: 10th April
That prom is a changer. I noticed that yesterday.
- robert
Re: 10th April
Thanks Alexandra.
What a good memory you have. It was when I first got the LS60 sevral years ago and using it with a Chameleon 3 I got horrible rings. I tried lots of stuff and asked on the forum. I think you were one of my helpers. A tilter was suggested so I got one that keeps the axis unaltered more or less and adjusted it until it worked. I have just measured the tilt and it seems to be 5 degrees. I have never touched it since, it just works.
So the image plane is not perpendicular to the axis but I guess the stacking and sharpening software sorts most of that out. No rings though!
Best
Robert
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Re: 10th April
Nice captures Robert, thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 20440 times
- Been thanked: 10246 times
Re: 10th April
Very nice results Robert! Try running some electrical tape around the open section of the tilter to make it light tight, you might be surprised the increase in contrast you get.
