April 8th _ Ha and CaK
Has thanked: 64 times
Been thanked: 4340 times
Post by MapleRidge »
Good day everyone...
Another clear day with moderate seeing this past Thursday, and I had a short window to image over my lunch break.
The full disk Ha image below is a composite of separate disk and limb exposures, with the limb inverted. Although there were no named AR's there are a few brighter points, as well as filaments and proms. The image shows a faint extension of the NE filament as a prom, extending into space at the 11 o'clock position of the disk:
The next full disk is a CaK image taken through the Celestron CR-150 OTA and Lunt B1800CaK module:
The CR-150 has be setup again in DS mode using the two DSII modules and B1800Ha blocker. These images were captured with the ASI290MM camera and 2x focal extender:
Has thanked: 20442 times
Been thanked: 10248 times
Re: April 8th _ Ha and CaK
Good set of images Brian! I was hoping to image before work today, based on the forecast, but it's raining again so I guess will have to see if it's any better when I get home.
Thanks Mark :bow
I hope the skies co-operate for you...cold, grey, and rain today. Welcome to Canada...was 22C and sunny on Saturday but today is not cold enough for snow, but not far from it :lol:
MAURITS
Has thanked: 2412 times
Been thanked: 4787 times
Post by MAURITS »
Beautiful images Brian.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Thanks Maurits...much appreciated :bow
Been thanked: 4904 times
Post by eroel »
Brian:
Beautiful images all of them.
Thanks for your comments Eric...very much appreciated :bow
