Good day everyone...
Another clear day with moderate seeing this past Thursday, and I had a short window to image over my lunch break.
The full disk Ha image below is a composite of separate disk and limb exposures, with the limb inverted. Although there were no named AR's there are a few brighter points, as well as filaments and proms. The image shows a faint extension of the NE filament as a prom, extending into space at the 11 o'clock position of the disk:
The next full disk is a CaK image taken through the Celestron CR-150 OTA and Lunt B1800CaK module:
The CR-150 has be setup again in DS mode using the two DSII modules and B1800Ha blocker. These images were captured with the ASI290MM camera and 2x focal extender:
April 8th _ Ha and CaK
- Has thanked: 65 times
- Been thanked: 4455 times
- Has thanked: 20940 times
- Been thanked: 10587 times
Re: April 8th _ Ha and CaK
Good set of images Brian! I was hoping to image before work today, based on the forecast, but it's raining again so I guess will have to see if it's any better when I get home.
Thanks Mark
I hope the skies co-operate for you...cold, grey, and rain today. Welcome to Canada...was 22C and sunny on Saturday but today is not cold enough for snow, but not far from it
- Has thanked: 2501 times
- Been thanked: 4924 times
Thanks Maurits...much appreciated
- Been thanked: 5015 times
Thanks for your comments Eric...very much appreciated
