Sunday Sun 11th April 2021
- Has thanked: 8596 times
- Been thanked: 8325 times
Another beautiful day with an almost cloudless start, so another opportunity for solar imaging in Ha and Ca II K. With half decent seeing (for a nice change) I even tried a close up view of the bright plage area towards the east.
Hydrogen Alpha FDs in Mono and Colour:
Lunt 60
Basler acA2440-75 um
1.5X Barlow
2 Pane Mosaic
20210411_Ha_FD_Mono by Stuart Green, on Flickr
20210411_Ha_FD_Colour by Stuart Green, on Flickr
Calcium II K FDs in mono and colour:
Altair Astro Lightwave 72mm
Lunt B1800 CaK module (modified)
1.5X Barlow
20210411_CaK_FD_Mono by Stuart Green, on Flickr
20210411_CaK_FD_colour by Stuart Green, on Flickr
Seeing that the conditions were pretty good, I switched over to my Tecnosky 125 mm for a closer view of the bright plage region.
Basler acA2440-75um camera
2.5x PM
The images have been cropped a little.
20210411_CaK_2_Mono by Stuart Green, on Flickr
20210411_CaK_2_Colour by Stuart Green, on Flickr
Interestingly there are some bright points in the core of this region of magnetic froth, presumably indicating an increasing concentration of magnetic flux in these regions. There's also a little dark core. Maybe sunspot genesis......?
20210411_Bright Points by Stuart Green, on Flickr
Thanks for looking.
Lunt 60
1.5X Barlow
2 Pane Mosaic
1.5X Barlow
2.5x PM
Thanks for looking.
- Has thanked: 9387 times
- Been thanked: 6201 times
Re: Sunday Sun 11th April 2021
Cracking images, Stu ! Here cloudy and will rain most of the day.
Thank you Stuart for sharing your excellent images and the close-ups too
Regards
Regards
- Has thanked: 3329 times
- Been thanked: 1907 times
Nice HA image.
Proms on the left much as I saw them.
Cheers. Andrew.
Nice HA image.
Cheers. Andrew.
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Lovely captures Stu, thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- VasilevIvan
- Has thanked: 400 times
- Been thanked: 267 times
Perfect images of Ha and CaK, Stu!
Sense of 3d effect when look on Ha image.
Ivan.
Ivan.
Best regards, Ivan.
VANTIM. Two Brothers observatory.
Observatory Dome 2.85m
SolarMax II 60mm DS, SW MAK 150, SW 80 ED, TS-Optics 6'' f5,9, LightBridge 12'' // AZ-EQ6 Pro, HEQ-5 mount
DayStar Quark Chromosphere, Lunt CaK B1800, D-ERF Baader 6'' // ZWO ASI 174mm, ASI 183mm, ASI178mm, ASI462mc, Player-One Apollo-M MAX.
- Martin_S
- Has thanked: 999 times
- Been thanked: 3061 times
Well done Stu ,those images are real crisp.
Martin
Martin
- Has thanked: 17960 times
- Been thanked: 17110 times
Stuart,
It looks like you have captured a couple of pores in your excellent CaK closups. Your Ha and Cak full discs look great too!
- Has thanked: 20962 times
- Been thanked: 10593 times
Super shots Stu! If you compare those bright points in CaK you find they are contemporaneous with small pores in WL.
- mattwastell
- Has thanked: 2 times
- Been thanked: 72 times
Many thanks, everyone. Really appreciated.
