Still with thin clouds but clear breaks.
127mm Triplet UV/IR 4.2x Quark Chrom 40mm Plossl
10.40 BST
See the spiricules and mottles on the surface.
1.00 One large prom on today. Pyramid on left and smaller one on right. Diffuse dumpy pyramid prom in between. On the right of the smaller pyramid a little feed with a space around it.
2.00 Tiny spike
4.00 Little jet pointing down with thicker jet going off the end upwards and two antenae off the top.
10.00 Tiny upward leaning spike.
I see a dark spot in the feature with a dark bar above left and one below it. To the right is the bright armchair still with a small dark spot under the seat by the left leg. 3 bright spots under joining the two spots.
Cheers. Andrew.
Visual Report 13/04/2021
- Has thanked: 3329 times
- Been thanked: 1907 times
Re: Visual Report 13/04/2021
Carbon60 shows a tall faint prom.
Going back I missed a thin leaning up prom at 8.00 for me, opposite side to the large prom.
5.00am Learmonth shows that.
It also shows a series of proms opposite, from the 4 prom group yesterday? Have another look for those.
Cheers. Andrew.
Cheers. Andrew.
- MAURITS
- Has thanked: 2501 times
- Been thanked: 4928 times
