A tall flame and AR12814
- krakatoa1883
- Has thanked: 153 times
Today a tall flame prominence is visible on the E limb, those who can shouldn't miss the view
Thanks for looking!
AR12814 in the southern hemisphere is growing although it is still of class B, it's more interesting in H-alpha than in visible light. Another small region is developing close to the SE limb and based on STEREO others will follow in the next days.Thanks for looking!
- 2021-04-14-0749-WL-fulldisc.jpg (372.66 KiB) Viewed 498 times
- 2021-04-13-1113-Halpha-AR12814.jpg (124.73 KiB) Viewed 498 times
- Has thanked: 9387 times
- Been thanked: 6201 times
- arnedanielsen
- Has thanked: 6353 times
- Been thanked: 7411 times
- Martin_S
- Has thanked: 999 times
- Been thanked: 3061 times
Re: A tall flame and AR12814
Nice imaging Raf, the prominence looks interesting.
Martin
Martin
- Has thanked: 2501 times
- Been thanked: 4928 times
- Radon86
- Has thanked: 763 times
- Been thanked: 663 times
Hello Raffaello,
Great work, I like these images a lot. Including the 1st one. I never thought about a small scope like a 50mm. I have a similar guidescope, a Altair 60mm guide scope with a F ratio of (225/60)=3.75
I wonder if I could use with a Quark ?
1) Did you upgrade the focuser on your Evoguide 50mm, as I understand it is a helical focuser.
2) Also the ASI178mm, I have not seen that used so much. It has small 2.4 um pixels. Did you focal reduce this to get to critical sampling as of :
http://www.wilmslowastro.com/software/f ... D_Sampling
You would best focal reduce to about F9 with your 50mm scope and 2.4micron pixel size at H-alpha.
Thanks Raffaello,
Magnus
Thanks Raffaello,
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
- Has thanked: 18105 times
- Been thanked: 8942 times
- krakatoa1883
Thanks for your comments.
I am very happy of the 178 which is fine for full disc and in some instances also for hires. Having very small pixels it requires modest f/ratios and therefore the use of reducers as a 0.7x or 0.5x depending on the setup. For hires imaging a 174 would be a better alternative.
Hi Magnus, you can see the setup in this discussion. The focuser is fine and smooth, I had just to replace the original eyepiece holder with a better one.
- Has thanked: 17969 times
- Been thanked: 17112 times
Very nice! I wish I could figure out how to get full discs with my Coronado SMII 90. Doesn't anyone make an optical element to half the focal length hence the magnification? Barlows/Powermates increase the FL hence doubling it or more.
Nice work on all three!
- Been thanked: 5016 times
- Has thanked: 8596 times
- Been thanked: 8327 times
Nice images, Raf.
FD's are normally captured using a Focal Reducer James.
Checkout the website https://astronomy.tools/calculators/field_of_view/ where it gives options including FR's etc.
Should answer your question - I hope ??
Regards
Regards
- krakatoa1883
Thanks for comments, much appreciated
James, you can make use of a reducer like these below screwed on the standard nose of my 178MM the left one gives 0.52x the right one 0.35x (although it too is labelled as 0.5x). More expensive (and less aberrated) reducers are available from few suppliers as Baader Planetarium, however for your first tests the above can be fine and are also cheap, which one is best for you depends on focal length and sampling.DeepSolar64 wrote: ↑Thu Apr 15, 2021 3:27 pmI wish I could figure out how to get full discs with my Coronado SMII 90. Doesn't anyone make an optical element to half the focal length hence the magnification?
Raf,
I will have to look around for a US dealer that carries these. Thanks. Where did you get these?
- krakatoa1883
Simply go on ebay.com or Amazon and type "eyepiece focal reducer" in the search bar, otherwise you can find them from the usual dealers of eyepieces.
