A tall flame and AR12814
krakatoa1883
Has thanked: 153 times
Been thanked: 496 times
Post by krakatoa1883 »
Today a tall flame prominence is visible on the E limb, those who can shouldn't miss the view
2021-04-14-1026-Halpha-fulldisc proms.jpg (48.69 KiB) Viewed 482 times
AR12814 in the southern hemisphere is growing although it is still of class B, it's more interesting in H-alpha than in visible light. Another small region is developing close to the SE limb and based on STEREO others will follow in the next days.
Thanks for looking!
Raf
Has thanked: 9280 times
Been thanked: 6125 times
Re: A tall flame and AR12814
Post by ffellah »
There are great, Raf. The close up is beautiful.
arnedanielsen
Has thanked: 6276 times
Been thanked: 7288 times
Post by arnedanielsen »
Great work, Raf.
Arne
Arne
Martin_S
Has thanked: 999 times
Been thanked: 3060 times
Post by Martin_S »
Nice imaging Raf, the prominence looks interesting.
Martin
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Beautiful images Raf.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Radon86
Has thanked: 763 times
Been thanked: 663 times
Post by Radon86 »
Hello Raffaello,
Great work, I like these images a lot. Including the 1st one. I never thought about a small scope like a 50mm. I have a similar guidescope, a Altair 60mm guide scope with a F ratio of (225/60)=3.75
I wonder if I could use with a Quark ?
1) Did you upgrade the focuser on your Evoguide 50mm, as I understand it is a helical focuser.
2) Also the ASI178mm, I have not seen that used so much. It has small 2.4 um pixels. Did you focal reduce this to get to critical sampling as of :
http://www.wilmslowastro.com/software/f ... D_Sampling
You would best focal reduce to about F9 with your 50mm scope and 2.4micron pixel size at H-alpha.
Thanks Raffaello,
Magnus
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
Has thanked: 17888 times
Been thanked: 8887 times
Beautiful and clean images, a pleasure to view :bow :hamster:
krakatoa1883
Thanks for your comments.
Boso36 wrote: Thu Apr 15, 2021 6:02 am) Did you upgrade the focuser on your Evoguide 50mm, as I understand it is a helical focuser.
Hi Magnus, you can see the setup in this discussion. The focuser is fine and smooth, I had just to replace the original eyepiece holder with a better one.
I am very happy of the 178 which is fine for full disc and in some instances also for hires. Having very small pixels it requires modest f/ratios and therefore the use of reducers as a 0.7x or 0.5x depending on the setup. For hires imaging a 174 would be a better alternative.
Raf
Has thanked: 17807 times
Been thanked: 16940 times
Post by DeepSolar64 »
Very nice! I wish I could figure out how to get full discs with my Coronado SMII 90. Doesn't anyone make an optical element to half the focal length hence the magnification? Barlows/Powermates increase the FL hence doubling it or more.
Nice work on all three!
eroel
Been thanked: 4957 times
Post by eroel »
Raf:
A very good session.
Best regards.
Has thanked: 8523 times
Been thanked: 8251 times
Post by Carbon60 »
Nice images, Raf.
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
FD's are normally captured using a Focal Reducer James.
Checkout the website https://astronomy.tools/calculators/field_of_view/ where it gives options including FR's etc.
Should answer your question - I hope ??
Regards
krakatoa1883
Thanks for comments, much appreciated :)
DeepSolar64 wrote: Thu Apr 15, 2021 3:27 pmI wish I could figure out how to get full discs with my Coronado SMII 90. Doesn't anyone make an optical element to half the focal length hence the magnification?
James, you can make use of a reducer like these below
screwed on the standard nose of my 178MM the left one gives 0.52x the right one 0.35x (although it too is labelled as 0.5x). More expensive (and less aberrated) reducers are available from few suppliers as Baader Planetarium, however for your first tests the above can be fine and are also cheap, which one is best for you depends on focal length and sampling.
Raf
Raf,
I will have to look around for a US dealer that carries these. Thanks. Where did you get these?
krakatoa1883
Simply go on ebay.com or Amazon and type "eyepiece focal reducer" in the search bar, otherwise you can find them from the usual dealers of eyepieces.
Raf
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Post by p_zetner »
Very nice images, Raf.
Peter
