Prom on the 14th.
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Prom on the 14th.
Didn't know if I should post these, but it's interesting to see the difference with Cak and Ha with the same prom and nearly the same time. I was pushing the scopes as the seeing wasn't great even though it was clear skies.
- 20210414-104116UT-Prom-col.jpg (270.62 KiB) Viewed 246 times
- 20210414-104116UT-Prom.jpg (233.5 KiB) Viewed 246 times
- 20210414-091845UT-Prom-cak-col.jpg (174.34 KiB) Viewed 246 times
- 20210414-091845UT-Prom-cak.jpg (1004.47 KiB) Viewed 246 times
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 17960 times
- Been thanked: 17106 times
Re: Prom on the 14th.
The color in the first image looks familiar ! The prom shows up nearly as well in your CaK image as it does in your Ha image. You are not alone. Seeing often tortures me too!
- Has thanked: 2501 times
- Been thanked: 4926 times
- Stardust5858
It's very frustrating isn't it.DeepSolar64 wrote: ↑Thu Apr 15, 2021 4:48 am The color in the first image looks familiar ! The prom shows up nearly as well in your CaK image as it does in your Ha image. You are not alone. Seeing often tortures me too!
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Thanks Maurits, still experimenting, lol.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 18105 times
- Been thanked: 8941 times
Very interesting indeed! the structures which are CaK bright are very different to Halpha bright. Generally the most energic regions seem to be the CaK bright, a good prom lift off is great in CaK. https://www.telegraph.co.uk/travel/gall ... n-ramsden/
That's a pretty-good capture Nigella considering the conditions.
I note that at present 0900hrsZ there is still or another similar prom.
Thanks for sharing
Thanks for sharing
- Stardust5858
Thanks Terry for the heads up, hopefully get a look.EGRAY_OBSERVATORY wrote: ↑Thu Apr 15, 2021 7:55 am That's a pretty-good capture Nigella considering the conditions.
Thanks for sharing
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
It certainly is. And then there are the clouds...Stardust5858 wrote: ↑Thu Apr 15, 2021 6:16 amIt's very frustrating isn't it.DeepSolar64 wrote: ↑Thu Apr 15, 2021 4:48 am The color in the first image looks familiar ! The prom shows up nearly as well in your CaK image as it does in your Ha image. You are not alone. Seeing often tortures me too!
- Stardust5858
Yep, "THE CLOUDS'DeepSolar64 wrote: ↑Thu Apr 15, 2021 3:43 pmIt certainly is. And then there are the clouds...Stardust5858 wrote: ↑Thu Apr 15, 2021 6:16 amIt's very frustrating isn't it.DeepSolar64 wrote: ↑Thu Apr 15, 2021 4:48 am The color in the first image looks familiar ! The prom shows up nearly as well in your CaK image as it does in your Ha image. You are not alone. Seeing often tortures me too!
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 8588 times
- Been thanked: 8324 times
Nicely done, Nigella.
- Stardust5858
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
