April 15 2021 Observations. WL only.
Has thanked: 17572 times
Been thanked: 16691 times
Post by DeepSolar64 »
Session time is 1:30pm until 1:50pm EDT local time ( US ). Skies are mostly to partly cloudy. The temperature is 59F. Seeing is fair.
Orion 70mm Solar Telescope. 25x and 50x ( WL )
I can see three spot groups on the Sun today! First is AR12814 now in the SW quadrant. It contains a dozen or so small spots/pores with some trailing off into a tail from the main body of the spot cluster. East of AR12814 is another small group in which I can see half a dozen pores split in two sections. There is a third group very near the eastern limb. I can see three spots within this one. I can faintly see the faculae to AR12814 and the group near the eastern limb shows it's bright faculae easily. I see no trace of the faculae to the center group.
The fine granulation of the solar disc is visible.
Carpe Lumen!
Has thanked: 8415 times
Been thanked: 8161 times
Re: April 15 2021 Observations. WL only.
Thanks, James.
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Thank you James and yes it certainly looks as the Southern-Hemisphere "has it" today.
In fact is has been a while since southern spots are occurring and for three AR's - is looking good.
Cheers
dhkaiser
Has thanked: 1407 times
Been thanked: 899 times
Post by dhkaiser »
About time the southern hemisphere picked up.
Dan
South central Indiana
USA
Here is the latest SDO continuum image as of 12:30am EDT ( 4:30am UTC )
MAURITS
Has thanked: 2412 times
Been thanked: 4786 times
Post by MAURITS »
Thanks for the update James.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
You are welcome Maurits.
EGRAY_OBSERVATORY
These new spots at the S.E. limb are certainly quite large and dark, so hopefully they and the other southern spots will continue to provide some interest.
I would expect AR2815 and AR2816 to be allocated for these, but in which order is a guess at present.
Has thanked: 17666 times
Been thanked: 8787 times
Fantastic update James :hamster: I hope the weather holds for the weekend :)
Heading out now for today's session. :)
