Session time is 1:30pm until 1:50pm EDT local time ( US ). Skies are mostly to partly cloudy. The temperature is 59F. Seeing is fair.
I can see three spot groups on the Sun today! First is AR12814 now in the SW quadrant. It contains a dozen or so small spots/pores with some trailing off into a tail from the main body of the spot cluster. East of AR12814 is another small group in which I can see half a dozen pores split in two sections. There is a third group very near the eastern limb. I can see three spots within this one. I can faintly see the faculae to AR12814 and the group near the eastern limb shows it's bright faculae easily. I see no trace of the faculae to the center group.
The fine granulation of the solar disc is visible.
Carpe Lumen!
April 15 2021 Observations. WL only.
- Has thanked: 17853 times
- Been thanked: 16998 times
- Has thanked: 8559 times
- Been thanked: 8291 times
Re: April 15 2021 Observations. WL only.
Thanks, James.
Thank you James and yes it certainly looks as the Southern-Hemisphere "has it" today.
In fact is has been a while since southern spots are occurring and for three AR's - is looking good.
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
About time the southern hemisphere picked up.
Dan
South central Indiana
USA
USA
Here is the latest SDO continuum image as of 12:30am EDT ( 4:30am UTC )
You are welcome Maurits.
These new spots at the S.E. limb are certainly quite large and dark, so hopefully they and the other southern spots will continue to provide some interest.
I would expect AR2815 and AR2816 to be allocated for these, but in which order is a guess at present.
Fantastic update James I hope the weather holds for the weekend
Heading out now for today's session.
