Quick AR with Tal/PST mod early doors 16/4/21
- DJD
- Has thanked: 42 times
- Been thanked: 133 times
Tried a quick session with my Tal/PST mod this morning.
Still frost on the ground but seeing not cooperative so gave up after a hour.
Not really much to show, but managed to get one30 frame image from a 1500 frame concatenated SER with the PGR G3.
I have processed the life out of it.
Hope everyone has better luck with the seeing.
David
David
- Has thanked: 9319 times
- Been thanked: 6157 times
- DJD
Re: Quick AR with Tal/PST mod early doors 16/4/21
Many thanks Franco, much appreciated.
I have reproccesd the raw footage without using the plastic bag flat and
using The FFT/ Bandpass filter to try to relieve the flat field problems in the same raw image.
Otherwise the same processing ( except the obvious colour addition ).
David
( Best seen full size, Right click and choose "view image" )
David
- Has thanked: 17853 times
- Been thanked: 16995 times
Very nice David. Your plages came out nice and bright.
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Nice capture David, thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Well-nice capture David and thanks for sharing
- Stardust5858
Still a nice capture David. Thanks for sharing.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 4980 times
David:
Very nice image in 2 versions.
- DJD
Thank you all for the nice comments, very much appreciated. Hopefully
we all get a bit of good seeing to cheer us up.
David
David
