Belated HA and CaK from 16th April
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Hi lovely people. Belated images from the 16th April 2021. Only just managed to process these today after another imaging session. Two days of imaging still to process. Scopes used were the Lunt 60mm DS and the 100mm CaK Achromatic. Zwo Asi 178mm Cameras. False colour added in PS CS2.
- 20210416-091454ellabryant-hafd-col.png (6.83 MiB) Viewed 270 times
- 20210416-091454ellabryant-hafd.png (2.29 MiB) Viewed 270 times
- 20210416-094723ellabryant-AR-col.png (844.68 KiB) Viewed 270 times
- 20210416-075812ellabryant-CaKfd-proms.png (1.83 MiB) Viewed 270 times
- 20210416-075812ellabryant-CaKfd-proms-col.png (5.26 MiB) Viewed 270 times
- 20210416-075332ellabryant-CaKfd-col.png (5.89 MiB) Viewed 270 times
- 20210416-075332ellabryant-CaKfd.png (2.02 MiB) Viewed 270 times
- 20210416-072525ellabryant-CaK-AR-col.jpg (559.1 KiB) Viewed 270 times
- 20210416-072525ellabryant-CaK-AR.png (620.11 KiB) Viewed 270 times
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Re: Belated HA and CaK from 16th April
Wow Ella, such a beautiful set of images with a great presentation.
- Stardust5858
Thanks Maurits, much appreciated.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Hi Nigella, your images are excellent and interesting too..
The artist in you - is certainly showing some fab colours and the presentation is just as good too...
Thanks for sharing
Thanks for sharing
- Stardust5858
Thanks Terry, I am a bit of an amateur artist, I have been known to dable, lol.EGRAY_OBSERVATORY wrote: ↑Mon Apr 19, 2021 12:34 am Hi Nigella, your images are excellent and interesting too..
Thanks for sharing
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 4980 times
- Stardust5858
Thanks Eric, appreciated.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Beautiful work I've yet to process my images from Saturday so you are not alone where does time go in the day?
- Stardust5858
Thanks Alexandra, I know, life gets in the way, lol.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 8558 times
- Been thanked: 8290 times
You had a busy, productive, session there, Nigella.
- Stardust5858
Thanks Stu, yes, I did. Appreciate your comment.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
