Had a quick session early morning hoping to get better seeing.
Did not really work out as seeing was very intermittent.
Anyway I am trying out a few FFT techniques to get rid of NRs and doing flat fielding
rather than use plastic bag flats.
Looks like I might have got some stacking errors in my first effort of 30 frames from
a 2000 frame concatenated SER. Also not sure that the technique brings out the best
of the proms rather that doing a separate run for them.
Hopefully some prom pics later ( and probably redo this active region ).
Hope everyone gets some time to play today.
David
Quick AR from early doors 19/04/21 Tal/PST mod
- DJD
- Has thanked: 42 times
- Been thanked: 133 times
- Has thanked: 9387 times
- Been thanked: 6201 times
- Been thanked: 5016 times
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Re: Quick AR from early doors 19/04/21 Tal/PST mod
Nice capture despite the seeing, my seeing was somewhat challenging too today.Thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 18105 times
- Been thanked: 8942 times
That's a lovely one David, you will soon remember what you used to do before
- Has thanked: 8596 times
- Been thanked: 8325 times
That's a cracking image, Dave.
- Has thanked: 20962 times
- Been thanked: 10593 times
Good shot! Are you using a tilter David?
- Has thanked: 65 times
- Been thanked: 4462 times
Well done Dave
- Has thanked: 2501 times
- Been thanked: 4928 times
