April 19th 2021 - Lots of goodies!
- Has thanked: 1071 times
- Been thanked: 1985 times
Seeing was on point today so i went on a capturing spree and ran out of drive space.
Esprit 150 with Daystar Gemini in Chrom mode and the Lunt Herschel Wedge for white light.
- rcwinter
- Has thanked: 191 times
- Been thanked: 265 times
Re: April 19th 2021 - Lots of goodies!
Wow, really nice set of images < I would like get images that show the surface detail and proms , do you overlay or something like that, still trying to figure out how to do that
Brilliant set , thanks for sharing
Rich
Rich
Baader DERF 90 & 160. Vixen SP102M Moonlite, Takahashi TOA130 Feathertouch 3.5, Takahashi FSQ106N, Daystar Quantum SE .4ang, Apollo Max, ZWO ASI 174MM. 2600mm, 178MM, Lumenera Skynx & Infinity 2
Those are great Simon. You might consider a larger drive for days like this one.
Phil
Phil
- Been thanked: 8793 times
These are gorgeous I really must try and process some I took at the weekend otherwise my drive will be filling up
- Has thanked: 8418 times
- Been thanked: 8165 times
Very nicely done, Simon. Great images.
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Lovely captures Simon. Thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
The images that show surface and proms are not overlays or composite images. They are shot and processed as is.
Shooting in 16 bit (ASI174MM is actually only getting 12 bit) allows you to see more than what is there. The processing that i use allows for both to show up at the same time.
- Has thanked: 17581 times
- Been thanked: 16697 times
Simon,
You not only have excellent processing skills, excellent equipment but also outstanding seeing. The mottles are resolved into spicules and your white light images are incredible with the granules clearly resolved. I am humbled by your images. Hats off to you with this wonderful set of solar goodies!!
- Been thanked: 2714 times
Very nice resolution and processing !
- Has thanked: 9145 times
- Been thanked: 6027 times
- Ivan
- Has thanked: 3465 times
- Been thanked: 2250 times
Cool photos! And how do you show prominences in chromosphere images? Do you do this in Photoshop using masks?
- Has thanked: 6181 times
- Been thanked: 7142 times
