Sunny but not good weather conditions. Very variable high cirrus clouds.
Full disc 19-04-2021
- Has thanked: 9401 times
- Been thanked: 5559 times
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Re: Full disc 19-04-2021
Rainer, you always capture excellent details not only on the surface but the proms and filaments as well.
Dan
South central Indiana
USA
USA
- Been thanked: 16689 times
You captured that filaprom superbly Rainer and though I was quite satisfied with my white light images today yours are still sharper with higher resolution. Did you use your FSQ-85 to image white light?
Hi James,DeepSolar64 wrote: ↑Tue Apr 20, 2021 4:51 am You captured that filaprom superbly Rainer and though I was quite satisfied with my white light images today yours are still sharper with higher resolution. Did you use your FSQ-85 to image white light?
Thanks and no. I do not move anything in my Solar equipment. The only thing I move in my Observatory is the roof and of course the mounts do move too.
Takahashi FSQ 85ED for H-alpha and Takahashi FS-78 for White Light.
- Has thanked: 8415 times
- Been thanked: 8161 times
Very nice images, Rainer, as usual. Great to see more activity on the Sun these days.
Hi Terry,EGRAY_OBSERVATORY wrote: ↑Tue Apr 20, 2021 4:19 pm As usual Rainer, your captures are just superb.
Thanks vm
I sent you a PM. regards Rainer
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Lovely captures Rainer, thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
rsfoto wrote: ↑Tue Apr 20, 2021 3:51 pmHi James,DeepSolar64 wrote: ↑Tue Apr 20, 2021 4:51 am You captured that filaprom superbly Rainer and though I was quite satisfied with my white light images today yours are still sharper with higher resolution. Did you use your FSQ-85 to image white light?
That little FS-78 does very well!
