New QUARK test, July 2 2021 AR12835 & 12837
Has thanked: 156 times
Been thanked: 893 times
Post by Valery »
Hi all,
It was about a year since I imaged the Sun last time (summer 2020).
On July 2 I managed to test my new Quark Chromosphere with very good homogeneity accross the FOV.
Here are two images (AR12835 and AR12837) taken with this Quark in a following set-up:
ARIES two band DERF D=140mm, SkyWatcher 150mm F/5 refractor, barlow lens which creates about F/35 with Quark's native 4.2x telecentric, focal reducer (about 0,65) and basler 1920-155 camera.
No flat fileld was applied. Contrast and brightness homogeneity are indeed so good that nothing to wish better.
And homogeneity does not changes with CWL tuning knob position changes within -5 to +5 positions.
Also this Quark is very narrow (less than 0.3A in my estimation).
Seeing was average and transparation was low, so low that I were need to rise the camera gain to nearly an upper limit and exposition to 8ms. Invividual frames are quite noisy and dim. I stacked 3500 frames to get a decent S/N.
Right click on the images to open them in a full resolution.
Thanks for looking.
Valery.
AR12835 2021-07-02 UT05h46m ARIES DERF SW150mm @F35 Quark-Chr Basler-1920-155.jpg
AR12835 2021-07-02 UT05h46m ARIES DERF SW150mm @F35 Quark-Chr Basler-1920-155.jpg (308.37 KiB) Viewed 683 times
AR12837 2021-07-02 UT05h42m ARIES DERF SW150mm @F35 Quark-Chr Basler-1920-155.jpg
AR12837 2021-07-02 UT05h42m ARIES DERF SW150mm @F35 Quark-Chr Basler-1920-155.jpg (422.66 KiB) Viewed 683 times
Has thanked: 17888 times
Been thanked: 8887 times
Re: New QUARK test, July 2 2021 AR12835 & 12837
That's a one in a million Valery :hamster: :bow :bow :bow
Glad to see you back imaging :)
Gingerfish
Has thanked: 60 times
Been thanked: 78 times
Post by Gingerfish »
WOW! Amazing images, Valery!
Clear sunny skies!
Chris
Lunt LS50THa
Lunt "Luntair" Altair 102ED
christian viladrich
Has thanked: 1 time
Been thanked: 2725 times
Post by christian viladrich »
Excellent Valery !!
BTW, we can now get good estimations of the the FWHM of Ha filters with Sol'Ex spectrograph.
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Excellent images Valery.
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Post by p_zetner »
I missed your images, Valery!
Great to see them again and these are beautiful.
Great results.
Peter
arnedanielsen
Has thanked: 6276 times
Been thanked: 7288 times
Post by arnedanielsen »
Very impressive images, Valery!
Thanks for sharing.
Arne
Arne
Valtori
Has thanked: 312 times
Been thanked: 182 times
Post by Valtori »
Very beautiful images, Valery!
Val
Petrus
Has thanked: 1578 times
Been thanked: 747 times
Post by Petrus »
Fantastic images, Valery!
~ Petrus ~
Flickr
Has thanked: 8523 times
Been thanked: 8251 times
Post by Carbon60 »
Great to see you back imaging, Valery.
Nice images. I was wondering how many Quarks you tested and rejected befor finding a good one :lol:
Post by Valery »
Thanks to all for your kind words.
To Christian. Nice to know that we some of us now can measure the FWHM of etalons we typically do use.
Question: have you measured your present mica spaced etalons and if yes, do they correspond to the declared FWHM? Same with air spaced etalons and other filters like BF and for CaK. If you have a time, please, give us your findings.
To Stu. I really don't know how many samples were tested. It was not me who tested them. BTW I believe this sample has better than 0,3A FWHM. I compared images taken with it with the images of the same ARs taken through etalons with known FWHM (0.2A, 0.3A and 0.4A).
My is somewhere in between 0.2A and 0.3A. Understandable that this is not really reliable estimations, but I do not have a better method.
Rusted
Has thanked: 8114 times
Been thanked: 1941 times
Post by Rusted »
Superb images! :bow
Is there any way for the humble imager to subjectively judge the quality of their etalons from their own [or other's] images?
Seeing conditions, aperture, objective, filtration, capture, processing and other factors obviously affect the average outcome.
How to judge etalon quality when conditions do allow the finest resolution?
Post by Valery »
Rusted wrote: Tue Jul 06, 2021 5:49 am Superb images! :bow
When comparing etalons with intention to judge which is narrower, first of all I look at the filaments length and thickness. The longer and the thinnier filaments are, the narrower the etalon.  Second factor to look at is a "fullness" in the "desert areas ".  The third factor is a contrast between the spicules and surrounding areas - lesser contrast - better. And forth - contrast between the penumbra and surrounding areas.
Hope my english allows adequate understanding what do I mean.
Rusted
Post by Rusted »
Valery wrote: Tue Jul 06, 2021 3:01 pm
When comparing etalons with intention to judge which is the narrowest, first of all I look at the filaments length and thickness. The longer and the thinner filaments are, the narrower the etalon. Second factor to look at is a "fullness" in the "desert areas ". The third factor is a contrast between the spicules and surrounding areas and forth - contrast between the penumbra and surrounding areas.
Thanks you Valery. :bow
Your eloquent description eclipses many whom only claim English as their first language. ;)
christian viladrich
Has thanked: 1 time
Valery wrote: Tue Jul 06, 2021 5:20 am
Hello Valery,
Up to now, I have measured :
- one SM 40 mm
- two SM III 60 mm
http://astrosurf.com/viladrich/astro/in ... sting.html
And two Ca K filters :
http://astrosurf.com/viladrich/astro/in ... lters.html
I have two PST in the pipeline.
Post by Valery »
christian viladrich wrote: Thu Jul 08, 2021 2:34 pm Hello Valery,
- one SM 40 mm
- two SM III 60 mm
Very interesting information! Well done!
Thanks for your efforts and time and then sharing these results with us.
pedro
Has thanked: 14 times
Been thanked: 6683 times
Post by pedro »
Great Quark images, I agree with Alexandra, it's one in a million
My Quark does not have an uniform field, I have to use flats
eroel
Been thanked: 4957 times
Post by eroel »
Valery:
Superb HR images.
As for my Ha filters, I just know that the old ATM that Del Woods made many many years ago is a 4.5A° etalon that has standed many decades and still works good.(this I have it at the rural observatory)
I also have a very old Daystar T-scanner of 4.5A°, that also Del made, and later Jen fitted it in a heated housing leaving the tilter on, this also still works well, though I am getting a central hotspot that could be cured with a new trimmer and blocker.(This I have it at my home observatory in Mexico City)
As for the big Aries ERF for the 10" f/20 TEC Maksutov, it is still in the mounting period, because I am making a cell to use it on the Meade 12" f/10 SCT., unfortunately my very good friend José Villicaña died and left some parts missing, so I am working on those, hope that for the winter period I will have everything ready to go.
Best regards and keep well my friend.
Post by Valery »
eroel wrote: Fri Jul 09, 2021 6:09 pm Valery:
Superb HR images.
Thanks for the info update and for good wishes.
Hope your etalons will work well on the 10" MCT.
PS. I believe your etalons are 0.45A°
