White Light Shots from Yesterday Morning with a ..... 3 inch.
Cschur
Post by Cschur » Wed Dec 28, 2011 8:24 pm
Hi all,
Here Im still pushing my 80mm f/6 to the limits to see what I can record on days of moderately good seeing. Yesterday morning was fairly good and I obtained some pretty hi res white light images. Now granulation is specified in most books at 1.5 - 2 arc seconds in size. Dawes limit for my 80mm is 1.4 arc sec, so by recording granulation clearly is really pushing the limit. Here is a shot with the 5x powermate, Continuum + IR, Wedge and 3 GB worth of data from the DMK51:
(click on this to see the big one for stars sake!)
Now here is a limb shot, same setup but a mere 500 frames:
On the opposite Limb, this one with good faculae:
A full disk shot, but this one was with Astro solar film, Contiuum + IR since I cant get to reach focus with my wedge at prime focus by about an inch.
Finally, I took this one while waiting for the sun to rise above the nearby pine trees. I live at a mile high elevation, and every tree is a pine tree!
Thanks for looking, Please feel to comment on what I am doing with the 3 inch...
Chris Schur
Pedro
Re: White Light Shots from Yesterday Morning with a ..... 3 inch.
Post by Pedro » Wed Dec 28, 2011 8:53 pm
Hi Chris:
Great HR WL images. You are really pushing your Zeiss 80mm to the limits. I usually image with a X2 apo barlow but the focal length of my FS128 is longer. It is difficult to do much better with the sun so low in the sky. Congrats.
You mentioned in a different post that you used AVISTACK. I prefer Registax. It is must faster (version 6) and it does a good jod. You have however to play a little with lots of options. I guess I now understood most of its aligning option. It you don't do it right you end up with a deficient alignment with lots of lines in the final image. Do you have the same experience?
best
Post by swisswalter » Wed Dec 28, 2011 9:27 pm
Hi Chris
fantastic shots and processing
Cschur
Post by Cschur » Wed Dec 28, 2011 11:48 pm
Pedro, I had to use AVIstack because Registax 6 will not open files from my DMK51 larger than .999 GB. BUT there is another reason I use it - just for stacking, it batch processe the massive amounts of data in about 2 hours, and the images are ready to post process in Registax wavelets which is far, far better! I will let you know how this works out. As you can see by the first image here, it found all the clear spots in the granulation. when I processed the 1gb shot - which was only 500 frames, in Registax - half the image was blurred. Each is good at something different.
Chris Schur
solarchat
Site Admin
Site Admin
Has thanked: 7 times
Been thanked: 105 times
Post by solarchat » Thu Dec 29, 2011 12:15 am
great artistry in the last shot Chris...I like it
Stephen W. Ramsden
Atlanta, GA USA
http://www.solarastronomy.org
Has thanked: 2224 times
Been thanked: 862 times
Post by marktownley » Thu Dec 29, 2011 12:27 am
Brilliant images Chris! B)
Pedro
Post by Pedro » Thu Dec 29, 2011 12:53 am
Hi Chris:
I guess you need a new computer with more RAM to process your images. I use a Toshiba laptop i5 4Gb RAM. It works fine.
best regards
earl
Post by earl » Thu Dec 29, 2011 1:57 am
really nice images. thanks for sharing
Has thanked: 2442 times
Been thanked: 839 times
Post by Montana » Thu Dec 29, 2011 10:05 am
The first is absolutely gorgeous but I must say the last shot took the favourite position!
Regards
Cschur
Post by Cschur » Thu Dec 29, 2011 2:56 pm
Thanks Everyone! I think granulation is what defines a good white light shot. The more the better. Im surprised a bit on how well it shows up even on a full disk shot with the green filters. That was un expected. Ill try to get a shot of the observatory today with all the snow around it....
Chris Schur
Pedro
Post by Pedro » Thu Dec 29, 2011 3:06 pm
Hi Chris. Please send the observatory shot with snow. It will be interesting to star a topic describing the setups we use to observe and image the Sun. I guess Bill already sugested that. Shall we do it?
best regards
PS- We still have clear skies in Portugal (15 days straight and going...). High clouds but no rain will arrive in two days ;)
Cschur
Post by Cschur » Fri Dec 30, 2011 4:18 am
Yeah, its all cactuses and sandunes. But NOT at 6000 feet at my observatory in happy jack. (See latest sky and telescope on the Discovery Channel telescope near my house)
Here is the snow shot I took today. It was below freezing at sunrise, and what in the world was I doing outside solar imaging? ;)
Chris Schur
solarchat
Site Admin
Site Admin
Post by solarchat » Fri Dec 30, 2011 6:40 am
Do you ever smile?
Stephen W. Ramsden
Atlanta, GA USA
depes
Post by depes » Fri Dec 30, 2011 8:08 am
Hi Chris
Beautiful all images...special the last ;)
Post by Montana » Fri Dec 30, 2011 11:54 am
Oh my...
You live in the most wonderful place, I am so envious. I guess you can't see much looking that way, what is the view like 180 degrees round? you are so lucky. Do you just drop off a cliff that way? could be dangerous in the dark if you exited that side :)
Regards
Cschur
Post by Cschur » Fri Dec 30, 2011 6:47 pm
Im on a big flat plateau just before the rim steep cliffs start. Its in a small subdivision, with about a hundred houses or so. the view the other way is solid pine trees.
Chris Schur
Post by swisswalter » Fri Dec 30, 2011 7:27 pm
Hi Chris
thank you for that shot. Fantastic view. Yes, me too I miss some movement in your mouth angles ;-)
JimLafferty
Post by JimLafferty » Fri Dec 30, 2011 7:38 pm
Super Shots Chris!
Jim
Jim Lafferty
Redlands, California
Author of "Imaging Our Sun"
Lunt 100T/Ha
Coronado 90/DS
Luntanado
ES127ED Triplet
ES80ED Triplet
DMK 41 USB Camera
SKYRIS 445M USB 3 CCD Camera
ZWO ASI 120mm Camera
http://scopetrader.com/jimlafferty
