Post
by MapleRidge » Sun Jan 22, 2012 11:41 pm
I've been having issues uploading these images...thanks to Stephen for his suggestions...if the images are here they worked :cheer:
Ok, so finally a clear day here with decent seeing and at -8C it is 10 deg warmer than my last two goes at the Sun
. Imaged from my backyard observatory near Cambray, ON Canada.
I have posted a pair of Ha images, each through a Lunt LS80T solar scope, double stacked with a Lunt LS75FHa etalon and a B1200Ha blocking filter. The full disk used a 0.8x telecompressor to give about 450mm of focal length, and the higher res image uses a 2x teleconverter to give me 1,120mm of focal length. The camera is a Lumenera Infinity 2-1M, controlled via Lucam Recorder and processed in Registax.
There were many small scale changes and interactions between groups during the 2 hour window that I was imaging. The large filament was very impressive, and if it holds together for another few days it will make an impressive prominence.
Photos:
https://www.flickr.com/photos/185395281@N08/albums
Deep Sky Work - Canon 60D (Ha mod), SBIG STF8300/FW8, ONAG
8' Diameter Dome
MI250 Mount carrying:
iStar 150mm, f8 OTA Modular Setup
Lunt LS80PT/LS75FHa/B1200Ha
