Ha Images fron Jan 21st
Has thanked: 10 times
Been thanked: 667 times
Post by MapleRidge » Sun Jan 22, 2012 11:41 pm
I've been having issues uploading these images...thanks to Stephen for his suggestions...if the images are here they worked :cheer:
Ok, so finally a clear day here with decent seeing and at -8C it is 10 deg warmer than my last two goes at the Sun :). Imaged from my backyard observatory near Cambray, ON Canada.
I have posted a pair of Ha images, each through a Lunt LS80T solar scope, double stacked with a Lunt LS75FHa etalon and a B1200Ha blocking filter. The full disk used a 0.8x telecompressor to give about 450mm of focal length, and the higher res image uses a 2x teleconverter to give me 1,120mm of focal length. The camera is a Lumenera Infinity 2-1M, controlled via Lucam Recorder and processed in Registax.
There were many small scale changes and interactions between groups during the 2 hour window that I was imaging. The large filament was very impressive, and if it holds together for another few days it will make an impressive prominence.
C9.25 Edge + Stellarvue 110, f7 or C14
Deep Sky Work - Canon 60D (Ha mod), SBIG STF8300/FW8, ONAG
Planetary Work - SBIG CFW10, ASI290MM/ASI462+ADC
8' Diameter Dome
MI250 Mount carrying:
iStar 150mm, f8 OTA Modular Setup
Ha configuration: 2xDSII/B1800Ha/Daystar ERF as modded Ha Scope
WL & CaK configuration: Lunt WL Wedge or Modded B1800CaK Wedge
Lunt LS80PT/LS75FHa/B1200Ha
Daystar Quantum 0.45A SE, Quark Combo Chromosphere,
ASI1600MM, ASI174MM, ASI290MM, PGR Grasshopper Express
Bill E.
Re: Ha Images fron Jan 21st
Post by Bill E. » Sun Jan 22, 2012 11:52 pm
I like both, thanks
solarchat
Site Admin
Site Admin
Has thanked: 7 times
Been thanked: 106 times
Post by solarchat » Mon Jan 23, 2012 1:25 am
I went in and clicked the "insert" button here so they would show in the post.
Stephen W. Ramsden
Atlanta, GA USA
http://www.solarastronomy.org
Post by MapleRidge » Mon Jan 23, 2012 2:47 am
Thanks for setting the images up to display...I think that most of my problem posting was with the comapatability mode. Will try more when I get a chance.
8' Diameter Dome
swisswalter
Post by swisswalter » Mon Jan 23, 2012 5:57 am
Hi Brian
very fine shots and congrat's, now it works with your upload
Has thanked: 3447 times
Been thanked: 1418 times
Post by marktownley » Mon Jan 23, 2012 6:57 am
Those are good! I like!!! :)
Look forward to seeing more of your work...
Derek Klepp
Been thanked: 171 times
Post by Derek Klepp » Mon Jan 23, 2012 7:48 am
Nice pics Brian look foward to more with the Lunt 80
Has thanked: 3237 times
Been thanked: 1234 times
Post by Montana » Mon Jan 23, 2012 10:02 am
Fantastic! I really like that filament, it would be amazing on the edge.
Regards
Cschur
Post by Cschur » Mon Jan 23, 2012 12:28 pm
Brian, stunning images, the full disk is especially compelling.
Chris Schur
