Processing a DSLR image--first try
Hi folks--
Another online solar amateur sent me a full disk in Ha (jpg) he shot with a Canon 7D. He has never really tried to process an image yet from his DSLR so he asked if I'd give it a try. Being my first time as well with a DSLR shot I said "sure" lol. Obviously starting with a jpg instead of the raw data was not the most desirable method but we work with what we have, right? Anyways you can see the processing flow and results on the below web page---actually came out better than I expected for a single frame at the mercy of the seeing (he caught proms and disk on one shot) and for not having any stacking involved. Anyways for what its worth, enjoy!
http://scopetrader.com/jimlafferty/?page=319
Jim
Jim
- solarchat
- Site Admin
- Has thanked: 83 times
- Been thanked: 1315 times
Re: Processing a DSLR image--first try
Jim,
I posted a few trials with this a couple weeks ago here. tell your friend to change to monochrome mode and take about 20 shots with very low exposure. Then he can stack them in registax and get some pretty good results.
Stephen W. Ramsden
Atlanta, GA USA
http://www.solarastronomy.org
Atlanta, GA USA
Ahhh thanks Stephen--I will have him do that---Im not familiar with DSLR's at all so that is great info!
Jim
Jim
- solarchat
- Site Admin
there is also a link on www.solarastronomy.org about half way down about imaging the Sun with a Canon 7D
Stephen W. Ramsden
Atlanta, GA USA
Atlanta, GA USA
Perfect! I added your links to the webpage and gave him the info! thanks!
Jim
Jim
- Been thanked: 4340 times
Hi Jim...
The DSLR pics came up quite well for the first try. Nice work!
- Has thanked: 20435 times
- Been thanked: 10245 times
Good result! I can see this is going to be the year where DSLR Ha imaging takes off...
- Has thanked: 17667 times
- Been thanked: 8789 times
That is incredible how processing can change an image to such an extent, well done!
Regards
Regards
That's a super write up...will give me something to do playing with some of mine....
This was my processing routine for DSLR Ha imaging http://www.photosbykev.com/wordpress/ph ... r-imaging/ It worked well for me I don't think switching to mono during capture is the right way to go, in theory only the red channel should capture detail but I often see data in the green channel which can used to improve the final image. Extracting the channels from the RGB image in post processing gives you access to all the data.
Shhoting multiple images and pushing them through Registax will certainly give more detail.
Well, I'll stick with my DMK but its nice to know a DSLR will work in a pinch!
Jim
Jim
Well done Jim. I have heard as well you can use the G channel as well when the full red image is blown out.
Chris Schur
Successful try, no doubt, i´ll have to give a try to my DSLR camera.
- Been thanked: 171 times
Thats impressive Jim. I think this winter I will have to bote the bullet hibernate and learn PS.
Derek
Derek
