Images from Feb 9th
- Been thanked: 4434 times
Images from Feb 9th
Hello everyone...
I have finally managed to get a few clear days in a row, and finished tuning the DSII module on my LS80T over lunch yesterday and grabbed a few images. I am thinking that if I have a clear day ont he weekend I will diassemble the DSII and start over when I have more time...might not hurt to tweak it a bit.
Below is the full disk in Ha, thorough the LS80T/DSII/B1200Ha, Lumenera Infinity 2-1M + 0.8x telecompressor:
Teh following two images focuson the two larger proms in Ha, thorough the LS80T/DSII/B1200Ha, Lumenera Infinity 2-1M + 2x teleconverter:
There were other proms along the limb, but I was limited to image the two most prominant ones.
I also did a CaK image through the William Optics 72mm, f6 scope using the Lunt B1200CaK module. Same camera as the Ha shots.
For all images, image cature was via Lucam Recorder and processed in Registax 6. I save 300 frames as a SER file, then combimn and process the best 80% of the stream in Registax.
- solarchat
- Site Admin
- Has thanked: 84 times
- Been thanked: 1387 times
Re: Images from Feb 9th
Nixe work Brian. Thanks for posting!
Stephen W. Ramsden
Atlanta, GA USA
http://www.solarastronomy.org
Atlanta, GA USA
- Has thanked: 174 times
- Been thanked: 619 times
Are you taking separate exposures for the proms?
I find the DS needs a lot more on the proms than the surface.....
Hi Merlin...
The images are 'single' exposure settings, not a disk/limb composite.
Thanks Cai-Uso and Stephen for your comments. Will head hoem for an early lunch and try so more imaging.
Hmmm,
So what would be your "average" exposure time per frame?
Merlin...
I will check the data files and see what the exposure/gain settting were. I did a lot of playing around and do not recall the settings.
Brian,
That would be appreciated...I'm obviously having difficulty replicating your results with my DMK and SM60 double stack.
- Has thanked: 20828 times
- Been thanked: 10502 times
Top shots Brian! B)
Definitely something weird going on with your tuning ken...
Tuning or gain setting??
Merlin...
The full disk camera settings were :
Exposure = 17.8 ms
Gain = 1.01
Gamma = 1.00
Contrast = 1.00
Brightness = 1.0
Capture frame speed = 15 Fps
The Limb/Disk were :
Exposure = 15.2 ms
Gain = 5.00
Gamma = 1.00
Contrast = 1.00
Brightness = 1.0
Both Limb/Disk images were the same setting...wasn't sure if they were changed, but they were not changed as I wandered around the disk.
Let me know if you have more questions...will be back online tonight.
Exposure = 17.8 ms
Gain = 1.01
Gamma = 1.00
Contrast = 1.00
Brightness = 1.0
Exposure = 15.2 ms
Gain = 5.00
Gamma = 1.00
Contrast = 1.00
Brightness = 1.0
Tuning I think, I rarely have my gain above it's lowest setting. Have you ever reversed the order of your etalons? Mine 'work' one way but dont the other...
Mark,
Yes,
i've tried them both ways...I think maybe I'm getting a far narrower bandwidth than the others!!
Brian,
I usually have gain set down and 1/120s for surface (8ms) and 1/11s (90ms) for the proms....
Yes,
Brian,
- Been thanked: 171 times
- Been thanked: 8907 times
Super pictures! lots of filaments and can I see some new emerging flux regions to cause some excitement?
Regards
Regards
Brian,
Great pictures. They show a lot of plasma activity and the quiescent proms are still there.
Thanks for the views,
Fernando
Fernando
Hi Alexandra...
Thanks yor your comments, and see what looks to be a 'hot' spot rotating into view today on the SE limb in the CaK band.
I still have to process today's images and will post when I get a chancem
Take care,
Take care,
Hi Alexandra...
Take care,
Take care,
Merlin...
I'm not sure how close the camera settings will compare between the DNK and Lumenera cameras, even if they have the same chip.
Hi All...
I mistakenly labeled these images as Feb 9th....posted on the 9th, but actually imaged on the 8th.
Sorry for the confusion.
Mark,
Yes,
Brian,
There's something very weird going on here Ken. I think we need pictures now to further this diagnosis...
Yes,
Brian,
Hi Brian
very fine shots
very fine shots
