Early Morning Prom. Huge
- Been thanked: 171 times
Todays events unfolded that I had a 30 minute window at 7.15am this morning.Around 20:00UT 9th Feb. I had a quick look at the Sun with the 60mm Daystar and could not believe what I was seeing .I quickly set up the 100mm Lunt and got some snaps.The whole prom using the 2.4X extender the close ups using it + a 2x barlow. The changes in 20 minutes were significant. Shame I had to go to work.As an aside I have just looked to my right as my son points out a waning moon rising over the trees. It is a good day.
Re: Early Morning Prom. Huge
These are incredible Derek! the depth effect is wonderful as your pictures show the filament curving round the limb and upwards. Great work and very lucky!!
Regards
Regards
- solarchat
- Site Admin
- Has thanked: 84 times
- Been thanked: 1384 times
Nice work Derek. Im still laid up with finger injury...or I could have shared this with about 700 students...dangit!
Stephen W. Ramsden
Atlanta, GA USA
http://www.solarastronomy.org
Atlanta, GA USA
- Been thanked: 10489 times
Holy moley! That's a great sequence derek! Impeccable timing! B)
Hi Derek,
Amazing sequence !! The forth image (first colorized) shows a very thin loop... that is impressive.
It is amazing so much plasma's activity that we can see on these images without a single spot around. I am confused about this behaviour of the sun.
Outstanding job Derek.
Fernando
Fernando
- Been thanked: 4427 times
Hi Derek...
Those are incredible images...great results and hard work.
That is awesome Derek, it is very similar to what I saw yesterday before the liftoff.
I am curious what kind of mount do you use?
I have a HEQ5 PRO an older version but it does the Job
Hi Fernando...
I believe we have a new AR on the limb that does not show well (under the prom), and it looks to me like the prom is reaching back over the limb...probably more hidden activity influencing this one.
Hi Brian,
I see what you mean. Yes, I agree it is what looks like.
Thanks for your explanation,
Fernando
Fernando
Hi Derek
great stuff, very great stuff
