Hi All
I just got around to crunching some data from the other day. Here is my rendition of this nice grouping that some in the group have already imaged as it has been developing. Thanks.
Ted
AR1416 From Feb 12th
- Has thanked: 17667 times
- Been thanked: 8787 times
Re: AR1416 From Feb 12th
Oooh that is so beautiful!! very delicately done
What did you say your scope and camera was (I think I have forgotten)?
Regards
Regards
Thanks Alexandra, Always a fine line as to how much you push an image. I use a Lunt LS80tha and DMK41 camaera.
Ted
Ted
- Been thanked: 171 times
- Has thanked: 20424 times
- Been thanked: 10243 times
Thats excellent Ted! B)
Thanks Cai
I usually grab 1500 or so images and more as necessary if the seeing is not so good. I use avistack to get my raw image and have used registax as well. I then primarily use photoshop to apply varying levels of smart sharpening function and plugin's from focus magic, crispimage pro plus also noise reduction when noise becomes evident. Depending on the data and signal to noise, it may also first get some wavelet work in registax and deconvolution from maximdl. I find prom areas respond very differently to surface areas with these tools so I tend to separately process these. I use photoshop to colour the image. I am not very disciplined and tend to chop and change in my workflows, sometimes even forgeting what the hell I have done in what sequence!
Ted
Ted
