Although not sharp here are some Prominences from today with the Lunt 100 and 5x Powermate. Also one of the Active regions with my inverted negative. Once again lots of fast moving clouds but I needed a fix.
Some Magnification Madness
- Has thanked: 17646 times
- Been thanked: 8787 times
Re: Some Magnification Madness
Super pictures again Derek! you never fail to cheer up my morning cup of tea. Fast moving clouds, you are a master capturer :
Regards
Regards
Hey Derek, nice closups as usual ! I hear ya about getting a fix! I delayed getting to work this morning so I could grab some data. I started out with some good seeing and it fell apart within 15 mins and then high clouds formed. grrr
- Been thanked: 4340 times
Hi Derek...
A nice set of images from your session. That bright 'ring' seems to be holding up over the past few days.
- solarchat
- Site Admin
- Has thanked: 83 times
- Been thanked: 1313 times
Derek, I much prefer the prominences in their natural sharpness like this. Afterall, they are big clouds of plasma.
The one with the filament floating over the surface really looks like it does in the scope.
Stephen W. Ramsden
Atlanta, GA USA
http://www.solarastronomy.org
Atlanta, GA USA
- Has thanked: 20424 times
- Been thanked: 10242 times
Top shots Derek!
Hi Derek
greate shots. From time to time I have the same madness, I have not yet found a cure of it
