Solar disc and proms on July 13
Posted: Sun Jul 14, 2013 3:29 am
The surface disc was an 6 image mosaic using an LS80 at 1400mm and Grasshopper3(1" sensor).
The proms used were a 4 image stitch with the LS80 at 1120mm due to problems with the proms taken at 1400mm.
After stitching, the smaller scale prom circle was enlarged to be a good fit with the surface disc.
For higher res, go to:
http://giovannigabrieli.deviantart.com/ ... -385248663
