Feb 24th - H-Alpha images
Very good sunny day today and I recorded a lot of videos. But not much time to process them.
So this if a "first taste" of what I've done in H-Alpha with the Vixen PST mod.
A mosaic (colour and negative), a very intriguing piece of the surface and a huge set of prominences (more later as I process them).
I hope you'll like them.
Andrea
Andrea
- Been thanked: 8791 times
Re: Feb 24th - H-Alpha images
Thanks a lot everyone! :
I'm very happy with the prominences but I want to get better with the surface processing. Can anyone help me with that?
Alexandra... can you please describe me how do you process your great surface images... they look so soft and "natural" I'll give you more details on how I do proms
I'd really like to do a time lapse of a prominence. As soon as I got a "stable" setup and time to do it I'll surely start doing some.
Hi Andrea,
Nothing special really, for prime focus I process in Avistack 2, then use iterative Unsharp mask at 0.5 pixels, 25% and 0 threshold for around 14 times. For the 2x Barlow it is the same but with a pixel of 1.
For my prominences, absolutely nothing happens! sometimes I wonder if anything is working in the program. Only Registax wavelets work (vaguely). I get absolutely nothing like the detail you get. So what is different between the surface and the prom? I may add that if I have surface detail in the shot that sharpens lovely but the prom stays exactly the same - unmovable!
Regards
Regards
Thanks for the description. I'll test it with my images. I take different steps that are more or less the same for prominences.
There are a few things that are important for prominences. The first is etalon tuning. I use the same tuning for both surface and prominences. But I redo the tuning everyday as the PST etalon is quite sensitive. To tune it I look for the position where I have no gradient. To help me in that process I usually set a slightly longer than normal exposition so that the gradient (if any) burns the disk.
Once done that I don't touch the etalon for the whole session.
Then there are two ways to catch prominences: burning the disk (so you can focus on the prominences only and "eclipse" the disk) or keeping the disk portion but a little over exposed (just a setting before the disk shows burnings). The prominence are usually well visible in the recording.
The stacking. It is fundamental that the image aligning is perfect. This is a crucial step. I now use AutoStakkert2! And works very well. For proms I use AP 25 (lowest value). I don't do any wavelet with any software.
The AS2! output is the taken into Photoshop. I record with a 2.25 Barlow and use iterative Smart Sharpen 10%, 3.3 range for about 10/15 times. Then I do some Unsharp Mask (10%, 1 range) and then I blur it a little to remove artifacts. This is more or less what I uses for surfaces as well. So it seems that we take different post-processing steps. Sincerely I don't think that post-processing is the real difference. Something before must be the reason for your lack of details.
Coloring is also important but that would take another page
I hope I've given some idea to try and improve your proms like I'm sure I'll improve with your info for surface details
Thanks!
Andrea
Thanks!
Andrea
- Been thanked: 171 times
Wonderful prominance image, we have seasonal grass fires in these parts that look just like that at night.
- mattwastell
- Has thanked: 2 times
- Been thanked: 72 times
Hi Andrea
Really impressive images - as mentioned the prom is a great pic of an epic scene!
A joy to look at - thanks!
- Has thanked: 20440 times
- Been thanked: 10246 times
Hi Andrea, great shots!
To get more surface wise you could use masks and process the limb and disk detail seperately - then combine as an overlay using opacity. The High Pass filter in PS is also another option you need to explore...
Andrea, they came out excellent, That first one is stunning. B) Karma to ya
Hi Andrea,
Regards
Alexandra with Proms the greater Magnification I use the greater I apply wavelets to get some effect. Up to the middle and beyond in some instances
Derek
Regards
Derek
Wonderful shots--I probably missed it but what camera and how many frames do you normally use?
Jim
Jim
Hi Jim,
Thanks. I use a DMK41 monocrome camera.
The recordings are Made of 1000 frames and I usually stack between 10% and 30% of the frames.
Andrea
Andrea
I think that we are missing some important point about surface and prominences quality.
I use a PST Etalon that has a bandpass < 1.0 A while Alexandra is using something with probably half the bandpass.
Having a larger bandpass is good for priminences and bad for surface details. That's why people double stack.
Vice versa having a smaller one gives you more surface details but less prominences one. I don't know if there's a way to increase the bandpass of a telescope
I think that this consideration has to be taken into account as probably we are both experiencing the limits of our setups
Hi Andrea
a very fine prom shot with excellent processing :
Thanks Mark. Sometimes I do that. But I think that the real problem for surface details is in the PST etalon. It is has a <1.0A bandpass that is good for prominences but I should doulbe stack to have more disk surface details
Hi Andrea,
Thanks for all the info! I think the lower in bandpass the prominences get better, especially with my PST vs DSPST as they become more 3D in appearance and easier to capture on camera. With the Solarscope so far I just seem to get flat featureless prominences, however, may be I have just been unlucky with the proms on the days I get it out to look?
Regards
Regards
You have to sacrifice one of your PSTs and mod it. And you'll have a prominence monster
But you'll still need luck to be in the right place at the right time... can't help with that
It seems that I've finally found a way to improve my disk surface images. Now they have more details and look more "natural". I think
I did by using only one pass of Smart Sharpen initially but with 500% amount. And then some Unsharp Mask and Blur.
But the key seems to be not to have an iterative Smart Sharpen but only one pass of it.
I'll experiment with it more but for now the comparison between the image I did yesterday and today's one tells me that I'm in the right direction
Oh yes, that's very good! B)
- solarchat
- Site Admin
- Has thanked: 83 times
- Been thanked: 1316 times
Stephen W. Ramsden
Atlanta, GA USA
http://www.solarastronomy.org
Atlanta, GA USA
Hi André
extremely fine result
- Been thanked: 4340 times
Hi Andrea...
Those are excellent pics form the modded set-up.
uhhh.....WOW!
todays pic on www.solarastronomy.org nice work!
WOW! I am honored.
P.S. I'm from Italy
WOW! I am honored.
P.S. I'm from Italy
Hi André
congrats on the pic of the day :
Yeah! That's great. I'm just back from the seaside (sunny and warm day here, almost spring) and I've found that nice surprise!
Hi André
welcome back to the shore
Hi André
Most incredible if you think that only 10 days ago we were at -15°C with 2 meters of snow!
Hi Andréa
great you are on the spring side again
- solarchat
- Site Admin
I'll change it after work tonight...sorry
Stephen W. Ramsden
Atlanta, GA USA
Atlanta, GA USA
I missed this post earlier. The proms shot is just fantastic!
Ted
Ted
Andrea your images are better and better, thanks for sharing the processing technique.
