Jan 1st Massive Flare
- Has thanked: 2 times
- Been thanked: 101 times
Hi All,
It is a beautiful day for the beginning of the year here in New Zealand. After imaging earlier in the morning I decided to setup my grab-and-go scope ready for our summer holiday in 5 days time. Well, knock me down with a feather, there was a massive solar flare occurring. I panicked a bit to try to set up and capture the event as it was occurring extremely quickly as it was all over within minutes. It was a massive flare ejecting a large filament, have a look at the images. These three frame are about 6 minutes apart, the times of the capture are in the file name.
Used Tak FS-60C +1.7x module (FL=600mm) + SM40 + BF30 + DMK51, each image is a 2 frame mosaic.
George
George
DS External SM90 Etalons, Single External SM40 Etalon, BF30, WO FLT98 f/6.3, Tak FS-102 f/8, Tak FS-60C f/5.9, DMK51, DMK21
- mr40mm
Re: Jan 1st Massive Flare
Lovely capture and processing!
Astro-Physics 152mm F8 with 1200 mount, SkyWatcher 100mm F10, Celestron C-8, Baader Herschel Wedge Model P, DayStar Quantum PE .5 Angstrom, PGR FLEA-2 CCD video camera, Meade 14" RC with Astro-Physics 1200 Goto mount.
- solar
- Has thanked: 227 times
- Been thanked: 1374 times
Great capture George.
I missed out two days in a row.
Vixen 130ss SolarMax 90 BF30 EQ6 Pro, LX200 14, C8 CG5, Megrez80, Lunt 100 DS. EQ 8
ASI 120mm 290mm 432mm Lunt B1800 Cal-K + other stuff.
Skywatcher 150mm PST Mod2
Thank you Randy, I hurried the series of shots not to miss anything but found that I was not exactly on band. I have never seen such a large flare and fast moving filament.
George
George
Ralph, I had just taken off the scope with the SM90 Etalon from the mount and transferred the FS-60C with the SM40 in it's place. My eye just about popped out of my head when I saw the flare and filament, it just caught me off guard.
George
George
- Been thanked: 4427 times
That's an impressive catch George...your timing was most opportune for such a fast acting event.
Very well done : : :
- mattwastell
- Been thanked: 72 times
Excellent capture George. That dark arch is amazing!
Chris
Chris
Chris Schur
- solar
GeorgeThat how it happens George.
When that happens to me I take a few seconds to think it through and decide what I will do and then stick with it
As it turned out this morning I would have got all the flare if I had of gone there first. No matter I am happy with the proms.
I have an hour of the flare from about a third of the way in,it is in AS2 now. Will post one set soon but the animation might take a day or two.
- pstew
Great catch George
Paul
Timaru, New Zealand
LS152Tha/B34/DSII, LS80THa/B18/DSII, LS60Tha/B12, Grasshopper3(ICX687), Chameleon 3(IMX264)
Timaru, New Zealand
Thank you all for your comments.
Ralph: This was the first time that this has happened to me, seeing the filament appear, expand and then dissipate within a few minutes was a rare event at least for me. I also had an interrupted morning with visitors arriving and going. It was a split decision on what to do. It was a pity that I took off the SM90 Etalon and place the FS-60C fitted with the SM40 Etalon. I spent most of the morning before the flare trying different setting to improve my prominence capture technique, I still have to process these images.
George
George
- solar
George
Yeah when you least expect it. You did well.
George
Well done for capturing this event George. I only got to see it on GONG, but it was a good spectacle. There was an almost simultaneous eruption on the limb which almost blew the tree prom apart..
Allan
Allcart: I was able to capture the prominences as well in my imaging session. I suppose I was just lucky to be image the sun at the time. What really amazed me was the speed of the the filament expanding, usually large filaments hang around for a few days to a week or so.
George
George
Hi George
congratulations on the catch. Well done
- Been thanked: 171 times
Nice George check my post I caught the tail end at greater mag but had problems with the contrast.These events get the adrenalin pumping.
- Been thanked: 10489 times
This is stunning!
