Lou took this great image of a prom with his Lunt152 double stacked with a Quark
How to build a magnetometer- Tutorial
Moderator: marktownley
Post by Carbon60 » Sat Feb 15, 2014 7:35 am
Hi all,
I was asked to produce a write up on how to build a magnetometer, so I've pulled some notes together which I hope will be of some interest.
Magnetometry pdf.pdf
(2.01 MiB) Downloaded 454 times
The attachment explains it all, but basically the device is very sensitive and it enables even very small (sub nT) fluctuations in Earth’s magnetic field to be logged and plotted. CME impacts are particularly impressive and this device records every detail as the magnetic environment is impacted, compressed and distorted. Given its simplicity, it is remarkably good at reproducing magnetograms recorded by the professionals. Ideal for when the clouds roll in..... :)
Stephen/Ken, I'd be grateful if this could be transferred to the tutorial section.
Thanks.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
