Field of View Calculator
these are all of the great references that our users have shared with others.
Moderator: marktownley
Post by marktownley » Sat May 10, 2014 9:36 pm
I came across this field of view calculator before - it's pretty good I think with a decent database of both cameras and scopes. There's an option to put the sun in as the object too. You can drag the solar image around the view box to get to the limb...
http://www.skyatnightmagazine.com/field-view-calculator
I'll leave it in the main forum section for a day or two so people see it, then put it in the library.
Hope it's of use!
Derek Klepp
Re: Field of View Calculator
Post by Derek Klepp » Sat May 10, 2014 10:03 pm
Thanks Mark
solar
Post by solar » Sat May 10, 2014 11:19 pm
Thanks Mark, these things are always handy.
Vixen 130ss SolarMax 90 BF30 EQ6 Pro, LX200 12", C8 CG5, Megrez80, SBIG2000 MXC,
PGR 2.8 Grasshopper PGR Flea3, DMK21 ASI 120mm Lunt B1800 Cal-K + other stuff.
Skywatcher 150mm PST Mod2
axlefoley
Post by axlefoley » Sun May 11, 2014 5:46 am
Yep very handy I just had a go with a few settings and saved the link to the desktop, ta much Mark.
Alan
Post by swisswalter » Sun May 11, 2014 6:07 am
Hi Mark
thank you very much. Very handy
Post by marktownley » Sun May 11, 2014 7:49 am
I found one because I wanted to know what the fov would be with a 100mm f10 scope and a quark (use 4.2x mag factor) - it's pretty small!
