Tutorial: Pedro's Hi Res Ha
Posted: Wed Mar 21, 2012 2:02 pm
HIGH RESOLUTION H-ALPHA IMAGING TUTORIAL
LINK to my webpage (images are linked there)
http://re.apaaweb.com/image_processing.html
Acquire high resolution H-alpha images (50 to 75 gamma DISK/ 200 to 250 gamma PROMS - DMK cameras)
Save AVI files or SER files (12 bits) (DMK or SKYnyx cameras)
Align and Stack images in AVISTACK http://www.avistack.de/
Open REGISTAX http://www.astronomie.be/registax/
Open FIT file (aligned and stacked in Avisatck)
Process the combined image using Wavelet-based image restoration
Reset the Wavelet filter (500 to 1000 center value)
Use layer 1, 2 and 3 of Wavelet filter - gaussian (try several options)
Save image (16-bit TIFF file)
Process TIFF file in Photoshop PS CS5
Use Curves to adjust contrast and brightness if necessary
Use Shadow/Highlights option
Use Smart Sharpen or Unsharp Mask
False Color Mapping BLUE CHANNEL, GREEN CHANNEL, RED CHANNEL
Save the final 16-bit TIF file (no compression)
Convert to 8-bit and save JPG file (no compression)
Attachments: ps_cs5_ha-06.jpg (507KB)
a few screens with the settings I use for H-alpha and CaK imaging (full disk) Astro-Tech 80mm F/7 apo refractor + DMK41
