White light non-spectrohelioscope
Post by Merlin66 » Wed Mar 05, 2014 8:14 am
Discussing a possible design for a SHG with a local guy, I got thinking......
Why not "trial" a white light version just to tune the acquisition speeds/ software...could we come up with an "acceptable" white light scanned image????
The idea is pretty simple - you add a slit to the end of your favourite white light scope then image the slit gap with a camera lens/ DMK.....
As the slit scans across the solar disk you generate a series of "white light" strips - to be combined into a final image...
Hmmm sounds like a good mini- learning project.
Keep you posted...
Nick
Oh, I get it now!
Oh, I get it now!
Re: White light non-spectrohelioscope
Post by Nick » Wed Mar 05, 2014 11:07 am
There's two ways to do this - during capture or post processing.
Post processing thoughts first:
It's possible to capture at a rate X then in software sample at a lower rate. Interpolation allows for fractional variation. This takes more imaging storage space but allows the fine tuning of the sampling rate to create a circle.
The main issue is that the earths atmosphere will change the rate as the sun rises, peaks and then retreats due to the bending of light.
Lastly - it would be prudent to image and stack the slit in realtime then assemble the stacked slit images.
Capture - guide assistance
A guider that can capture basic details - such as sun spots - can be used to provide a registration point. This could be done in a set of ways:
* FFT alignment with an updated reference image to keep up with solar changes
* FHWM of the solar disk itself - probably best to make a multi-point to cope with convection.
The resulting registration point allows the accurate positioning of the slices.
Oddly enough my own app is built for realtime processing ;) (already has a form of FFT alignment, stacking etc)
Lastly it's possible to transform and register the spectra against known spectra.. a sort of astrotortilla but for spectra.
I think that the main issue is slit-wide resolution.. perhaps a diagonal scan is more preferable in this instance - map and then drizzle.
Cschur
Post by Cschur » Wed Mar 05, 2014 4:30 pm
Ken, you could also set a scope up in the daytime and point at a distant scene and just turn on the drive to scan this scene across the slit. Hold the fast button for accelerated scans.
Chris
Chris Schur
Nick
Oh, I get it now!
Oh, I get it now!
Post by Nick » Wed Mar 05, 2014 6:28 pm
Good point - or you could use a circular target with a lower fl scope/lens at the end of the garden. Just use a laser pointer to align the centre point.
Post by swisswalter » Thu Mar 06, 2014 5:30 am
Hi Ken
that project sounds great
alex
Post by alex » Fri May 01, 2015 6:32 pm
Nick wrote:There's two ways to do this - during capture or post processing.
Hi Nick!
Do you gave any info on this app? Sounds really interesting.
Alex
