22May2014 SHG images: 2nd installment.
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
More images from the 22May session.
1. H alpha (comparison with ChroTel telescope image).
2. H beta comparison with H alpha.
3. He D3 (comparison with ChroTel telescope He 1083nm image).
- Been thanked: 10489 times
Re: 22May2014 SHG images: 2nd installment.
These really are excellent Peter!
- Has thanked: 8559 times
- Been thanked: 8290 times
Looking really good there, Peter.
Nice work.
Nice work.
- p_zetner
Thanks, Stu and Wah.
Wah: The He D3 line is 587.6 nm. The absorption process in He is similar for the 587.6nm and 1083nm lines so the images should look similar (hence, the comparison with the ChroTel image). The lower (absorbing) level in both cases has an excitation energy around 21eV. These are very interesting absorptions and worth reading about. You should be able to see the D3 line in your instrument. I'd say a bandwidth of somewhere around 0.2A should be sufficient. As you've found, the on-disk He D3 absorption is extremely weak and basically, impossible to see. The trick is to take the on-band image and subtract or divide the nearby continuum. Strictly, division by the continuum is preferable but I've found this difficult to do! Subtraction gives me something to work with.
Peter.
Peter.
Hi Peter
wonderful results
wonderful results
- p_zetner
Last pic from the 22May2014 session.
It's an image in the Mg "b" lines, presented as a median average of images made in the b1 (5184A), b2 (5173) and b4 (5167) lines.
Peter.
Peter.
- Mg_b_lines_22May.jpg (207.86 KiB) Viewed 3607 times
Cool addition!
- fulvio.mete
- Been thanked: 84 times
All beatiful images, Peter, but I'm very interested in the Helium I 5876 A one!
- p_zetner
Hi Fulvio.
Yes, I find the He D3 images very interesting as well. Apparently, the dark absorption features (correlated with the chromospheric plage) are never visible in coronal holes. The lower absorbing level of He D3 is produced by extreme ultraviolet radiation generated in the corona and passing downward, back to the surface.
You won't be able to see the absorption line on the solar disk in your instrument. You can calculate where it is relative to the Na D lines. You can also see this line in strong emission near the solar limb. As the Sun's limb sweeps into view of your spectrometer, the He D3 line will become, momentarily, quite bright. It's one way to locate the line.
Peter.
Peter.
- Been thanked: 171 times
All good Peter .It would be interesting in all these wavelengths if you captured a large flaring region for comparison.Just have to hope you're in the right place when it happens.
Thanks Derek
Thanks Derek
- p_zetner
Absolutely, Derek!
There's a photo in Zirin's book of a flare taken in several wavelengths. Don't have the book with me at present, but remember being struck by the wavelength comparison.
Peter.
Peter.
- fulvio.mete
Yes, Peter. I know that, but till now I wasn'able to locate the He I line.Your suggestion to use the NaD lines as reference is very good.You won't be able to see the absorption line on the solar disk in your instrument. You can calculate where it is relative to the Na D lines. You can also see this line in strong emission near the solar limb. As the Sun's limb sweeps into view of your spectrometer, the He D3 line will become, momentarily, quite bright. It's one way to locate the line.
- Has thanked: 8 times
- Been thanked: 17 times
I also use Na line to find the HeD3, the line on solar edge is brightfulvio.mete wrote:Yes, Peter. I know that, but till now I wasn'able to locate the He I line.Your suggestion to use the NaD lines as reference is very good.You won't be able to see the absorption line on the solar disk in your instrument. You can calculate where it is relative to the Na D lines. You can also see this line in strong emission near the solar limb. As the Sun's limb sweeps into view of your spectrometer, the He D3 line will become, momentarily, quite bright. It's one way to locate the line.
http://solarchat.natca.net/viewtopic.php?f=8&t=9829
But my SHG is not high resolution enough to get good surface details…
