03Jun2014 PZ's SHG Images: He D3
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Post by p_zetner »
A favourite wavelength: the He D3 Fraunhofer line. Lots of black plage evident.
I didn't "pretty up" this image as much in order to show the bright He D3 limb.
The comparison image is a He 1083nm image from the ChroTel telescope.
Peter.
He D3:
He 1083nm (ChroTel):
Has thanked: 20732 times
Been thanked: 10427 times
Re: 03Jun2014 PZ's SHG Images: He D3
Excellent! How narrow is this line?
p_zetner
Post by p_zetner »
Cheers, Mark.
The author of the reference below gives a so-called "1/e width" of 0.4 Angstroms for the measured (Gaussian) absorption line profile in plages.
If you look at figure 2 of the reference, this amounts to a 0.6 Angstrom fwhm.
Reference:
Title: A measurement of the helium D3 profile with a birefringent filter
Authors: Labonte, B. J.
Journal: Solar Physics, vol. 53, Aug. 1977, p. 369-374.
Peter.
BTW: Daystar makes He D3 line filters at the low price of $12000 for a 0.4A (fwhm) bandpass and $15500 for the 0.3A bandpass (QPE) versions!
Post by swisswalter »
Hi Peter
interesting that He D3 line
DSobserver
Been thanked: 19 times
Post by DSobserver »
probably one day for me......
One question : how do you manage the setup of your grating?
Has thanked: 17888 times
Been thanked: 8887 times
:shock: wow! that is amazing!!!
alex
Post by alex »
Very nice and very interesting Peter!
Do you know why we have the H3 limb is so brightening?
Wah
Has thanked: 8 times
Been thanked: 17 times
Post by Wah »
Let me help you to remove more horizontal bands :mrgreen:
03Jun2014 HeD3.jpg (179.15 KiB) Viewed 3296 times
p_zetner
Post by p_zetner »
Thanks, Wah!
Did you use your technique of producing a flat from a crop and dividing?
I notice you use "divide" blending mode in Photoshop. I don't have this mode !?!
Trying it in ImageJ usually doesn't work well, so I use a horizontal lines suppression in ImageJ FFT bandpass filter.
Peter.
Wah
Post by Wah »
The Photoshop I use is version CS6, maybe you can try it.
Cschur
Post by Cschur »
Ok Peter, Im impressed. I really like this line too! One day I would like to build a high res spectrograph that can take such images. For now, my spectrograph is 2A resolution with the 2400 grating, and between the 300 grating, and the two others I have Im working now on getting spectra of more solar system objects - mainly comets with my 12 inch. However, I do have just enough res you think to try some calcium drift scans? What would a 2A Cak drift scan look like? Can you take one for me so I can see if its worth it or do I have to build a new spectrograph?
Once again, your shots have always inspired me to look more deeply into the subject of spectrohelio graphs, and seems like I learn something every time I open Kens book!
Spectra of Comet ISON with spectrograph:
http://www.schursastrophotography.com/i ... F-1290.jpg
Chris Schur
highfnum
Has thanked: 57 times
Been thanked: 1190 times
Post by highfnum »
Advanced stuff
but what does image
say?
p_zetner
Post by p_zetner »
Thanks, Chris.
With a 2400 /mm grating, you should be able to improve your resolution by a factor of 10, or more. Bandpass is dependent on line density of the grating, the slit size and the collimator focal length. The (reciprocal) dispersion (A per um or A per pixel) will depend on these factors and the camera lens focal length. The bandpass I get with such a grating is better than 0.2A, closer to 0.15A (25um slit, 500mmfl collimator lens). The reciprocal dispersion I get (270mmfl camera lens) is about 0.06A per pixel (4.5um px).
Here's a pic of CaK with a simulated bandpass of about 2A. It's pretty contrasty, but you will have more fun with a narrower bandpass.
Peter.
Has thanked: 174 times
Been thanked: 618 times
Chris,
Narrower slit gap and longer focal length lenses is the way to get an improvement....check out the options with SimSpecV4.
