06Jun2014 PZ's SHG Images: CaK (dispersion boost)
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Post by p_zetner »
Greetings Everyone.
I replaced my 2400 /mm grating with a 3600 /mm. I was a little surprised to see how large the improvement in dispersion was! The downside: a trade-off in intensity. Despite being coated for UV, operation with the 3600 /mm grating required a lot more gain to work in the CaK portion of the spectrum.
A happy observation was the clear delineation between the K2 and K3 portions of the K line. Here's a sample spectrum:
Ca K spec v2.jpg (162.45 KiB) Viewed 2128 times
Here are images made in the K1r, K2r and K3 lines:
The K3 image shows less contrasty sunspots and more apparent (if you look hard!) filaments since it images higher up in the chromosphere. If you're having trouble seeing a difference between K2 and K3, I produced a difference image (K3 minus K2r). I thought the filaments would stand out in this difference image, but that didn't happen. The active regions look quite different in the two lines, though.
Peter.
EDIT: The photos have gone through one revision since the initial posting. I think these are a noticeable improvement. Processing is everything!
Wah
Has thanked: 8 times
Been thanked: 17 times
Re: 06Jun2014 PZ's SHG Images: CaK (dispersion boost)
Post by Wah »
The results are sooo great !
You make me jealous now!!
p_zetner
Post by p_zetner »
Thanks, Wah!
Your images are outstanding. Maybe a higher resolution grating would increase the possibilities?
Peter.
Wah
Post by Wah »
An inexpensive + suitable size grating is not easy to find, can you tell me where to get one?
Been thanked: 1 time
Post by swisswalter »
Hi Peter
what a wealth of Information, thank you
