I think that finally everything is now ok with my SHG :
Ha
Cak
and first shot in He...
...and in Hb!
For the treatment, I found a really easy way to remove the lines : GIMP. I found an option to remove the trail. It works pretty fine here too (except in Hb...)!
SHG shots : Ha, Cak & He
- DSobserver
- Been thanked: 19 times
Re: SHG shots : Ha, Cak & He
Hi Vincent
great results
great results
- DSobserver
- Has thanked: 8 times
- Been thanked: 17 times
Why are the bands are not purely vertical or horizontal? I need to rotate the image 91.X degrees rather than 90 degrees.
- 659299hb060914_5_Processed.png (180.08 KiB) Viewed 2651 times
- DSobserver
because after your soft, the picture is little bit tilt of fiew degres.
The tilt is not from the merging program, but from the orientation of the slit.
You may tilt vertical direction rather than horizontal direction, which can leave a chance to remove the bands by others
- DSobserver
previously I was using vertical orientation with same issue...
I don't say that the problem is coming from your (great) soft but most probably it's a common issue with SHG 'cuase is not the first time I saw similar issue on other website....
In fact it's maybe (even most probably) because my mount is not perfectly align on the north...Don't you think?
- Has thanked: 20828 times
- Been thanked: 10501 times
What fantastic shots! I like them a lot!
As I said in my last reply, the tilt problem should be from the orientation of the slit. The slit has to be perfectly aligned to Earth North-South direction, or else it will introduce some tilt.
