Having not taken SHG images for quite a long time as I broke a prism inside during the disassemble.
I have my SHG fixed, but the results were bad.
It seems the camera was not cooperating with me and the frame rate varies while capturing the video...
Or maybe it was the problem from the EQ mount.
I will try to fix the problem next time.
20140921 Bad SHG results
- Has thanked: 8 times
- Been thanked: 17 times
- Hbeta 21_9_2014 17_32_18_000_3_FFDivided.jpg (117.46 KiB) Viewed 2130 times
- Hbeta 21_9_2014 17_30_43_000_5_Processed.jpg (104.15 KiB) Viewed 2130 times
- Ha 21_9_2014 17_27_18_000_5_Processed.jpg (122.75 KiB) Viewed 2130 times
- Ha 21_9_2014 17_26_01_000_5_Processed.jpg (98.82 KiB) Viewed 2130 times
Re: 20140921 Bad SHG results
Hi Wah
there is potential in your pics. Hope you can fix it what ever it is
- Has thanked: 20435 times
- Been thanked: 10245 times
You'll fix it Wah! I know you will
- Been thanked: 8790 times
Excellent pictures but strange shapes, we can all imagine them to be round though
Hope you fix it soon
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Hi Wah.
Are you using the "high speed scan" by driving the mount in reverse?
If so, why don't you try the old fashioned approach with the mount turned off?
This would indicate whether or not you have problems with the mount drive.
Peter.
Peter.
