20141018 Interesting lines
- Has thanked: 8 times
- Been thanked: 17 times
Although the collimation of my SHG is not done yet, I used it to see the solar spectrum last Saturday.
I have found so many more interesting lines that can possible see prominence, including the Mg and Na lines.
It is so pitty that my Mg line video file is crashed...
- Unknown4.jpg (15.55 KiB) Viewed 3294 times
- Unknown3.jpg (21.43 KiB) Viewed 3294 times
- Unknown2.jpg (25.73 KiB) Viewed 3294 times
- Unknown1.jpg (19.82 KiB) Viewed 3294 times
- Na.jpg (25.91 KiB) Viewed 3294 times
- Hgamma.jpg (21.57 KiB) Viewed 3294 times
- He.jpg (35.61 KiB) Viewed 3294 times
- Hdelta.jpg (26.41 KiB) Viewed 3294 times
- Ca.jpg (24.22 KiB) Viewed 3294 times
- Ha.jpg (31.21 KiB) Viewed 3294 times
Re: 20141018 Interesting lines
Hi Wah
interesting findings. I look forward to the pics of the disk
- Been thanked: 10489 times
Great stuff wah!
- Been thanked: 4427 times
Interesting images Wah...so much information in the spectrographs.
I think it needs very very narrow bandwidth to capture full disk of those weak prominence lines.
It is much easier to detect these weak lines by using the edge prominence.
- DSobserver
- Been thanked: 19 times
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Very nice, Wah.
Searching the web, I found some interesting material. Here's a link to some eclipse spectra, showing emission lines in the chromosphere.
http://www.eurastro.de/webpages/MRSPECT.HTM
Some of your unknown lines (are they in the green?) might be iron.
There's also a paper showing interesting "reversed" structure in the H lines in prominences (http://arxiv.org/abs/1210.5643).
It might be interesting to plot some of your emission lines and see what the lineshapes look like!
Peter.
Peter.
I didn't find many prominence in the green part of the spectrum.
The unkown1 was UV part, and the other unknowns are in the deep red to IR.
It is possible that some of them are overlapped with 2nd order UV spectrum.
Peter, your SHG has higher resolution than mine, I think you can capture more interesting lines~
Hi Wah
that looks great
that looks great
