Magnetometer Project
grimble_cornet
Re: Magnetometer Project
Post by grimble_cornet » Tue Jan 20, 2015 12:30 pm
Thanks guys - it certainly proves that the project is realistic :seesaw
The 'beer fridge' is just a 'cheapo' old fridge which lives in my extension and is used to store milk and beer. Your point about opening the door is a good one and the 25m lead to the buried sensor will only just reach it. I am also less than convinced that the fridge will maintain the temperature as accurately in the summer so ...................... its not really a long term solution.
If I was convinced that a small 'beer fridge' would work, I would install one in the observatory (yeah :P ) but I suspect that it would show more variation than a full size fridge.
I have pretty much decided to follow Stuart's solution using a heat mat plus a 'pulse' thermostat in a cool-box to maintain the temperature. This could live in the observatory or in the house within easy reach of the sensor cable.
Let's see what a 24 hour run produces once I change over to Stuart's 150 second sample routine.
Mike Garbett
Post by swisswalter » Tue Jan 20, 2015 11:42 pm
Hi Mike
great results with the fridge. I'm sad to see you leaving that simple method though, but I do understand the need of a beer or two a day ;)
grimble_cornet
Post by grimble_cornet » Wed Jan 21, 2015 12:32 am
Don't worry Walter, I have other stores of Beer (and wine) in other fridges :P
Well, here we go - a full 24 hour cycle of The Beer Fridge Magnetometer
I have 'smoothed' my data in the top right graph to simulate Stuart's 150 second sample rate - the top left graph shows my original 30 second data.
The agreement with the Niemegk data is not perfect - there is some variation from about 11am but each station seems to show a slightly different curve during times of low magnetic activity so........ not sure how concerned I should be about that?
The fridge temperature has been very consistent if you believe what the probe is reporting and the outside temperature has only varied by about 3 degrees C over the last 24 hours so I don't think the buried sensor will have been influenced very much?
Mike Garbett
Post by swisswalter » Wed Jan 21, 2015 5:25 am
Hi Mike
but that looks very promissing, almost perfect
Post by marktownley » Wed Jan 21, 2015 6:59 am
I agree looks good. Longer term testing and evaluation required!
grimble_cornet
Post by grimble_cornet » Wed Jan 21, 2015 12:19 pm
Your wish is my command:
I intend to run it from the fridge for a few days just to make sure that other aspects of the gear are behaving. I will then decide on a permanent set-up for the Bat 5 end of the cable.
In the meantime, here we have 42 hours of data from The Beer Fridge:
Here's to Walter for his inspiring idea:
And finally, here is this morning's data in more detail using Stuart's 150 second sampling rate - seems very 'frisky' with lots of 'pulses' when compared to Intermagnet?
Mike Garbett
Post by Montana » Wed Jan 21, 2015 12:47 pm
Well done Mike :hamster: :hamster: :hamster: we just need a CME now :)
grimble_cornet
Post by grimble_cornet » Wed Jan 21, 2015 12:53 pm
YES :band
That would be very nice :P
Mike Garbett
Post by marktownley » Wed Jan 21, 2015 5:50 pm
Is it worth putting an RF supressor on the fridge? They are 'electrically noisy' things as they turn on an off, and can play havoc with expensive hifi's - maybe they could have an adverse effect on the bat detector unit?
grimble_cornet
Post by grimble_cornet » Wed Jan 21, 2015 6:55 pm
It wouldn't surprise me if the fridge was generating noise Mark :oops:
I have had the washing machine and spin dryer, which live in the same room, working hard this afternoon so it will be interesting to look at tonight's trace :roll:
Mike Garbett
Post by Carbon60 » Wed Jan 21, 2015 7:30 pm
Hi Mike,
I don't know how 'remote' your sensor is in relation to other sources of interference, but these things are so sensitive that you could also be detecting movement of cars in the street, or other such things. From 20m away I can detect vehicles turning in our Cul-de-sac. The deviation only needs only to be a few nT to appear significant.
I think your system is now up and running really well for a home made system operating in a garden environment. Professional systems will be located in a remote field quite some distance from any sources of interference.
Wait for a CME event and I'm confident that you'll be more than happy with the magnetometer response. :band
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
Wah
Post by Wah » Thu Jan 22, 2015 12:17 am
Congratulations! Good to see such amateur professional results and I am now trying to introduce this to some of my friends from mainland China~
grimble_cornet
Post by grimble_cornet » Thu Jan 22, 2015 12:05 pm
Thank you Wah and I am pleased to hear that you are encouraging others to try this project - I have had a lot of fun getting to work.
Mike Garbett
grimble_cornet
Post by grimble_cornet » Thu Jan 22, 2015 12:29 pm
Thanks Stuart; I am pretty happy with the results I'm getting since moving into the fridge :lol:
I had the washing machine and tumble dryer working yesterday and they live next to the fridge :o
I got a temperature swing in the fridge (only a degree or so) but it had only a small impact on the results:
Here is 54 hours of Bat in the Fridge data compared with Intermagnet:
54 hours of Magnetometry.jpg (279.69 KiB) Viewed 2027 times
I'm pretty impressed with the correlation - especially now I realise how much the 'scaling' changes the appearance of the published graphs and makes it very difficult to combine 2 or 3 days worth of data.
I moved over to 150s samples for temperature and magnetic data last night and am very happy with the detail recorded during a minor event early this morning :seesaw
Anyway: I have decided to bite the bullet and have ordered a heat mat and thermostat - same models as you use - to create a permanent recording station without being concerned by fridge access, washing machine interactions etc. :lol: :D :lol:
Mike Garbett
Post by Montana » Thu Jan 22, 2015 12:43 pm
Congratulations :hamster: :hamster: :hamster: we now have an aurora alert base in the midlands too :hamster:
Post by swisswalter » Thu Jan 22, 2015 12:52 pm
Hi Mike
just wonderful results and many thanks for the beer ;)
Post by marktownley » Thu Jan 22, 2015 6:29 pm
Very funky!
Post by Carbon60 » Thu Jan 22, 2015 8:18 pm
Hi Mike,
As a point of reference, here are my data from the same period. Looks like we're in pretty good agreement. :band
Unsettled Geomag 20150122.jpg (82.9 KiB) Viewed 1990 times
NEQ6 Pro-mount
grimble_cornet
Post by grimble_cornet » Thu Jan 22, 2015 10:48 pm
Thanks for all of your support and encouragement folks :bow2
This thread seems to have generated a lot of interest and I hope other people will be motivated to have a go.
For me, it has provided precisely the complex, multi-variable, problem solving challenge which attracted me to science in the first place :seesaw
With any luck, the 'thermostatically controlled heat mat in a cool box' solution will provide a reliable long-term monitoring tool - watch this space ;)
Mike Garbett
Post by swisswalter » Fri Jan 23, 2015 6:24 am
Hi Mike and Stuart
you've done it, congratulations
grimble_cornet
Re: Magnetometer Project - death of the fridge
Post by grimble_cornet » Tue Jan 27, 2015 4:12 pm
Well, the weather has warmed up a little over the last few days and what I was afraid of has happened :evil:
Death of the fridge 1.jpg (113.87 KiB) Viewed 1935 times
The thermostat in the fridge cuts in as the temperature rises and we get a lovely 'spike' as the cooling cycle responds.
As can be seen from the image shown below, even a 2.5 degree change totally distorts the output from the Bat detector.
Death of the fridge 2.jpg (301.36 KiB) Viewed 1935 times
As the outside temperature continued to rise it became obvious that this 'cooling cycle' really sounded the death rattle for the 'fridge solution' :cry:
Death of the fridge 1a.jpg (235.38 KiB) Viewed 1935 times
In anticipation of this problem I ordered the same heating mat and thermostat which Stuart uses. It arrived yesterday and I set up my 'foam wrapped' Bat detector in an old cool box along with the mat. The thermostat was set to 27 degrees C, my temperature probe inserted into the wrapping around the Bat detector and the whole lot left to equilibrate.
As the temperature of the Bat detector increased from about 8 to 27 degrees C, the output frequency changed dramatically but eventually stabilised and I left it to run overnight.
First run with heat mat.jpg (265.92 KiB) Viewed 1935 times
There is good news and bad news; as always :roll:
The thermostat has reduced the 'overnight temperature drop' and the 'central heating 8am boost' to less than 1 degree C.
The bad news is that even this 'oscillation' is enough to distort the trace :o
Next step is to try to improve the positioning and insulation around the cool box in an attempt to 'damp out' the temperature fluctuation to something close to the 0.3 degrees which is required for excellent results - watch this space :lol:
Mike Garbett
Post by marktownley » Tue Jan 27, 2015 7:50 pm
watching with interest!
Post by Carbon60 » Tue Jan 27, 2015 9:19 pm
Hi Mike,
It still surprises me just how temperature sensitive the Magenta 5 actually is, considering it's supposed to be 'digital quartz' tuned. More insulation around the box should help, of course. Warmer weather will also help :)
NEQ6 Pro-mount
Post by Carbon60 » Tue Jan 27, 2015 10:06 pm
Hi Mike,
Another option to consider, maybe, is using a high heat capacity filler within the box, surrounding the Magenta 5. Maybe cobbles or small stones to fill the space, since these will absorb and release heat, helping to smooth out the variations (like a brick block storage heater). This will be much more efficient than air as a way of storing heat.
Just a thought.
NEQ6 Pro-mount
grimble_cornet
Post by grimble_cornet » Tue Jan 27, 2015 11:22 pm
Good point Stuart - I had considered going down that route with the FGM-3 after reading a link from the Speake website.
I was slightly worried about what filling or insulation would be safe to use with the heat mat but I guess it generates so little heat that there is no real fire risk.
I would like to avoid taking the Bat detector out of its case as I would have to do to get it inside a vacuum jar as you have done so have been considering alternatives.
My next move (if additional padding around the cool box doesn't work) involves putting the Bat detector in a polythene bag surrounded by sand in a large tin or glass jar - exactly the same logic as your 'storage heater' suggestion.
Watch this space...........
Mike Garbett
