ok guys need some help
highfnum
Re: ok guys need some help
Post by highfnum » Sat Jun 20, 2015 12:04 am
sunspot group upper right prom lower left
Post by swisswalter » Sat Jun 20, 2015 4:57 am
Hi John
that is a good progress
highfnum
Post by highfnum » Sat Jun 20, 2015 7:40 am
Yes I have some hope
highfnum
Post by highfnum » Sat Jun 20, 2015 9:17 am
i locked down unit on rail to keep stable
Post by Merlin66 » Sat Jun 20, 2015 9:27 am
Well done!
A bit more practise and you'll be kicking goals.....
Stick with the narrow slit gap...
Get the exposure to give you a deep absorption line, keep checking your focus and play around with the extraction of various bandwidths (# of pixels) from the spectral image.
You may also have to throw a light proof cover over the SHG to reduce unwanted reflections etc.
Onwards and Upwards.
highfnum
Post by highfnum » Sat Jun 20, 2015 10:20 am
Merlin 66
What about cleaning glass disk?
Post by Merlin66 » Sat Jun 20, 2015 10:33 am
Sure, it can be cleaned with alcohol/water mix....
The scan lines won't be coming from the slit gap - usually dust etc. will show as continuous "transversalium" lines across the image...
Hmmm
Question: in the presented image the scan seems to be across (horizontally) - is this correct?
highfnum
Post by highfnum » Sat Jun 20, 2015 12:21 pm
Ok I cleaned it there was a haze on it
not sure I understand Question
Post by Merlin66 » Sat Jun 20, 2015 12:25 pm
It's OK....
The vertical lines in your image are not caused by dust...
They come from somewhere in the processing..
