its it safe to say a SHG is born?
highfnum
Post by highfnum » Mon Jun 22, 2015 11:23 pm
my third attempt - much improved from "ok guys I need your help" thread
this shot shows -- proms , filaments, peach surface, flares
I still got a learning curve on getting brightness and how to fix picture size
would you guys say -- Yes you got a SHG?
question why is sun egg shaped - its it that im not square with slit and optical train?
can that be fixed?
with software
thesmiths
Re: its it safe to say a SHG is born?
Post by thesmiths » Tue Jun 23, 2015 1:35 am
It's definitely working. I assume one issue is that the slit is not perpendicular to the scan direction. I don't think that's absolutely necessary but it's obviously helpful if it's not too far off. The current data can be fixed by a transformation in Photoshop (rotate and then resize). Your slit looks very clean (I guess it is relatively wide?). It seems to me you need to improve the focus (of the Sun's image on the slit) since the edge of the Sun does not look extremely sharp.
Post by swisswalter » Tue Jun 23, 2015 4:06 am
Hi John
that is a further good result, congratulations
Post by marktownley » Tue Jun 23, 2015 5:26 am
Excellent stuff! I'm impressed!
Post by Montana » Tue Jun 23, 2015 9:22 am
:hamster: :hamster: :hamster: well done, filaments and plage :bow
DSobserver
Post by DSobserver » Tue Jun 23, 2015 12:00 pm
nice result!
Was your mount well align to the north? I think that this is the reason why you face this issue...
I often (always?) get this and playing with shearing and resize effect.
I also would suggest you to close a bit more the slit in order to decrease the wavelength pass
highfnum
Post by highfnum » Tue Jun 23, 2015 9:26 pm
thanks for all the kind words
very challenging project
Ive built my own solar scope and modded others but this SHG stuff
requires a bit of different thinking
Look I know i got a ways to go before images come close to SHG images
posted by others in this forum
but it does look like all the pieces are in place
it just getting thru details in the learning curve
I thank all -- ex: Merlin66, Wah! and others that help me with this one
this project - I will be tinkering for a long while
DSobserver
Post by DSobserver » Wed Jun 24, 2015 6:36 pm
a bit better :
highfnum
Post by highfnum » Wed Jun 24, 2015 7:22 pm
Yes it is merci !
what steps did you do to do fix
DSobserver
Post by DSobserver » Wed Jun 24, 2015 8:06 pm
I use freeware GIMP in french
1-Filter / "improve" /remove line
2- Tool / "transformation" / "shearing"
Do you use Wah soft? If yes, did you "play" with it to reduce the smiling effect? Indeed only the center of the sun show Ha wavelengt....
highfnum
Post by highfnum » Wed Jun 24, 2015 9:29 pm
yes I used Wah! software
but what is smiling effect?
see its a new world of things to know!
Wah
Post by Wah » Thu Jun 25, 2015 12:28 am
Congratulations!
You may use "skew" and "resize" (1 direction only) functions to make the solar disk round.
The upper part of the sun is a bit off band, it seems not from the smiling effect if the original video is in horizontal.
highfnum
Post by highfnum » Thu Jun 25, 2015 1:17 am
thx wah
i tried one of the off band lines just for fun
got this
not sure what it means
1) ha line is very dark compared to surrounding lines
2) looks like white line image
DSobserver im learning! i made this sun round
Wah
Post by Wah » Fri Jun 26, 2015 7:31 am
I use skew like this.
Post by marktownley » Fri Jun 26, 2015 8:12 am
I'm so going to have to try and make one of these...
highfnum
Post by highfnum » Fri Jun 26, 2015 3:08 pm
mark - if I can do you can!
Wah -- where is this skew thing
Wah
Post by Wah » Fri Jun 26, 2015 10:38 pm
2nd trial to remove vertical stripes:
highfnum
Post by highfnum » Sat Jun 27, 2015 3:13 am
thank you
its a bit of a learning curve
but I think i have no where to go but up with this
very interesting way of doing solar imaging
highfnum
Post by highfnum » Sat Jun 27, 2015 2:27 pm
Wah! plz
how did ypu make image more uniform?
