my attempts at SHG images continued
highfnum
Post by highfnum » Fri Jul 17, 2015 3:09 pm
still fighting with post image processing
but captures are getting better and cleaner
caH
highfnum
Re: my attempts at SHG images continued
Post by highfnum » Fri Jul 17, 2015 3:10 pm
CaK
highfnum
Post by highfnum » Fri Jul 17, 2015 3:12 pm
caH orig
hey if anyone wants to process for comparisons be my guest
DSobserver
Post by DSobserver » Fri Jul 17, 2015 8:58 pm
hello
you look t get a good slit.
Where did you get it?
highfnum
Post by highfnum » Fri Jul 17, 2015 9:06 pm
From merlin66
DSobserver
Post by DSobserver » Fri Jul 17, 2015 9:46 pm
here is my contribution
I would say that youhave to improve focus from the collimation lens : this is why the edge are focus but the surface is not as sharp.
I also would suggest you to try first Ha shot : indeed due to wavelenght, focus is easier
highfnum
Post by highfnum » Fri Jul 17, 2015 10:35 pm
So you say that prime image of sun on slit is a bit off?
MERCI for image!
Wah
Post by Wah » Sat Jul 18, 2015 1:11 am
Good clean slit and no de-banding is needed!
DSobserver
Post by DSobserver » Sat Jul 18, 2015 7:39 am
highfnum wrote:So you say that prime image of sun on slit is a bit off?
MERCI for image!
no, the focus of the lens after the slit. Indeed it is the most sensitive one.
How do you currently manage this ?
highfnum
Post by highfnum » Sat Jul 18, 2015 8:19 am
Manually
just once without scope attached
p_zetner
Post by p_zetner » Sat Jul 18, 2015 6:48 pm
The focusing does seem to be off. My technique: Before taking instrument into the field, adjust collimator and camera lens (without telescope in place) to get sharp spectral lines from an emission spectrum source (Ne, Na, Hg lamp, etc.) placed near the slit. Remaining focus, to be done in the field, is largely the telescope, with minor (repeat: minor!) tweaks of camera and collimator lenses. As Vincent mentions, the collimator is often the most sensitive adjustment.
Peter.
highfnum
Post by highfnum » Sat Jul 18, 2015 9:06 pm
thanks all for advice
did some tweak today
this may take several tries
before I get good feel for it
I hope I now qualify for entry into the SHG club
even at low tier
Post by marktownley » Sun Jul 19, 2015 6:24 am
Interesting to read your progress!
DSobserver
Post by DSobserver » Sun Jul 19, 2015 10:16 am
Here my advice base on friends advice and experience for a good focus :
1- I take my camera (450D) + long lens (400mm) a manage to get infinit focus to a mountain for example.
2- remove from your shg the telescope and the camera lens
3- oriente the SHG to the sun
4- through my 450D+400mm infinit, I manage to get a perfect slit image focusing the collimator (f/8 like this I avoid any specular light from the slit)
5- place again the camera lens on your shg and focus properly the spectra on the wavelenght you want
6- place the telescope and focus it in order to get a sharp spectra edge (in fact sun edge...)
7- adjust/finalise focus with camera lens
The longer the wavelenght the easiest it is to get a good focus....
highfnum
Post by highfnum » Sun Jul 19, 2015 5:35 pm
Ok
I think I understand
The slit edge should look sharp
As well as edge of sun within slit
space
highfnum
Post by highfnum » Sun Jul 19, 2015 6:15 pm
Marktownly your next!
highfnum
Post by highfnum » Sat Aug 08, 2015 8:30 pm
oversampling error
too many frames
then when i fixed clouds rolled in!
got two partials
oversample
highfnum
Post by highfnum » Sat Aug 08, 2015 8:31 pm
part with no clouds
Post by Merlin66 » Sat Aug 08, 2015 10:54 pm
That's looking good, mate!
Keep it up.
