Magnetometer data-G1 solar storm
Post by Carbon60 » Thu Jul 21, 2016 6:24 pm
A CME impacted with Earth's protective magnetic bubble (magnetosphere) in the late hours of July 19th, sparking aurora as the resulting G1 solar storm reverberated around our planet. The resulting magnetic fluctuations in Earth's magnetic field were captured on my magnetometer here in the UK, as shown below.
Image20160720_CME_G1 Storm by Stuart Green, on Flickr
The event started at around midnight (UT) 19th/20th and lasted throughout the following day, before eventually quietening down.
Thanks for looking.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
Re: Magnetometer data-G1 solar storm
Post by marktownley » Thu Jul 21, 2016 9:59 pm
A good result there Stu!
grimble_cornet
Post by grimble_cornet » Thu Jul 21, 2016 10:40 pm
Great report Stu :bow2
Similar result here...... give or take a bit of thermal noise thanks to the mini heat wave :lol:
19-20th July.jpg (66.51 KiB) Viewed 1950 times
Mike Garbett
Post by Carbon60 » Fri Jul 22, 2016 11:17 am
Cheers Mark/Mike.
Looks good, Mike. I'm glad it's all still up and running.
NEQ6 Pro-mount
Post by Montana » Fri Jul 22, 2016 11:24 am
Great to see both of you picked it up, lets hope we get more now the nights are drawing in :hamster:
highfnum
Post by highfnum » Fri Jul 22, 2016 7:50 pm
nice work
rxdeath
Post by rxdeath » Sat Jul 23, 2016 5:06 pm
getting this kind of data is really awesome...can we see a picture of your instrument? that would be really cool to have one, i've been thinking about ham radio so i can listen to the 10cm band, this would be awesome too, did you build it or is this a commercial device? can you reference where you got it if so?
i'll answer my own question if you too are interested in this, see the tutorial he made here:
viewtopic.php?f=7&t=10349
grimble_cornet
Post by grimble_cornet » Sat Jul 23, 2016 5:31 pm
You may also be interested in this 'extended discussion' in which Stu helps me to build and operate a replica of his magnetometer :D
viewtopic.php?f=8&t=14485
Mike Garbett
rxdeath
Post by rxdeath » Sun Jul 24, 2016 3:50 am
ok you two are awesome. i want one. i'm in sacramento so this could be interesting because i'm quite a bit farther away. if i do one and we can get someone in oz interested that would be close to the DSN!
i have power lines behind my house at 400v (typical for normal res power lines in the us, steps down to split phase 240 at the transformer on the pole) so i think the impact would be minimum, for me the thermal regulation will be difficult as our temperature right now swings from around 15-35. in the 'winter' it's much better, but i'll have to plan for summer, winter will come easy then.
my garden is unfortunately closer to the power lines in my backyard, is there a good test one could do see if the interference is above a certain level? i have really only 2 places where it's practical to dig and the other is close to my neighbors property line so i couldn't guarantee nonchanges/noninterference from there, so the garden seems like the best option. however 'practicality' has rarely been my driving force in astronomy lol, i am more than happy to kill a fly with a cannon.
also in the appendix of stu's write up it shows a case with 2 bat dets in it...does that case go in a tub that has a heat mat, or how do you thermally control those? was it pre-vacuum flask? how intense is getting cables in and out of vacuum flask (drilling, etc)? has anything dramatically changed since the end of the extended discussion?
props, what an awesome project!
Post by Carbon60 » Sun Jul 24, 2016 6:53 am
Hi 'Rxdeath',
Glad this has sparked some interest. There is an updated description which Mark will transfer to the tutorial section, but basically it just covers what is presented in the thread that Mike pointed you to.
Power lines could be an issue, especially with a transformer with obvious EM effects, as the device is very sensitive. Try to position it as far away from such things as possible.
Other than getting someone in to undertake a survey, the only option might be to build one and see, with the risk of wasting time and money if there is too much interference and it doesn't work.
The other issue is temperature, as you have recognised. This is the reason for the vacuum flask, cool box and heater mat which is all a bit of a pain, but worth the effort. There is a bit of drilling and fiddling to be done getting the wires and glands sorted, but nothing too challenging.
Let me know if you are going ahead and I can guide you through the steps, although the thread Mike pointed you to covers a lot of the groundwork.
NEQ6 Pro-mount
p_zetner
Post by p_zetner » Sun Jul 24, 2016 2:20 pm
Great results, Stu (and Mike).
Hopefully there will be a reasonable number of these events to record as the Sun winds down to activity minimum.
Peter.
