ROT2 command of IRIS
Merrill55
Oh, I get it now!
Oh, I get it now!
Post by Merrill55 » Tue Dec 13, 2016 11:30 am
Hi, Ken Harrison,
I'm Toshio Ohnishi. I'm old amateur Spectrohelioscope maker.
Recently, I made short spectroheliograph. This is not completed yet.
I have some trouble about IRIS of C.Buil.
I using AZW174MM as CCD.I do't know to use ROT2 command.
What can I should do to ROT2 command? ROT command is OK.
Toshio Ohnishi
Has thanked: 4 times
Been thanked: 20 times
Re: ROT2 command of IRIS
Post by Merlin66 » Tue Dec 13, 2016 3:34 pm
Toshio,
Welcome to the group!
I have limited experience with IRIS but will investigate the ROT2 command for you.
I would recommend that you download Wah!'s SLiM (Spectral Line Merge) program from the library section; it's much easier to use and is very effective.
Can you give us more detail of your SHG.
Has thanked: 1199 times
Been thanked: 490 times
Post by marktownley » Tue Dec 13, 2016 8:08 pm
Welcome Toshio! I always admire your SHG images on facebook, glad you found your way here :)
highfnum
Been thanked: 39 times
Post by highfnum » Tue Dec 13, 2016 9:20 pm
welcome Welcome Toshio!
I also saw your recent post on daystar filters FB
Yes a lot of us use Wah! merge program
Post by Merlin66 » Tue Dec 13, 2016 9:42 pm
Toshio,
Looking at the command line structure of ROT2.....
Command: ROT2 [IN] [OUT] [XC] [YC] [ANGLE] [NUMBER]
where
[IN] - generic name of the sequence of images to be treated (e.g. Solar_in)
[OUT] - generic name of the rotated images (e.g. Solar_out)
[XC], [YC] - the pixel coordinates of the centre of rotation (e.g. 150, 400)
[ANGLE] - the applied rotation in degrees (e.g. 8)
[NUMBER] - the number of images in the sequence (e.g. 25).
Example
ROT2 Solar_in Solar_out 150 400 8 25
Merrill55
Oh, I get it now!
Oh, I get it now!
Post by Merrill55 » Wed Dec 14, 2016 2:31 am
Thank you all.
Telescope 80mm FL=910
Collimator(Camera) 70mm FL=700
Grating 1800L/mm 5000A Brazed
Slit width=20micron
CCD ASI174mm
The SLIM is not work in my windows10.
When I push Merge button,it shows 'System.NullReferenceException'.
SLIM monitor
SLIM monitor
relay lens on the eyepiece folder
slit
slit
folded up parts
folded up parts
telescope and colimator lens
CCD and eyepiece
CCD and eyepiece
Overview
Overview
Post by Merlin66 » Wed Dec 14, 2016 2:40 am
Toshio,
Hmmm
I think that means your AVI is larger than the 2Gb limit.
You need to use VDub to rope around the line of interest to reduce the file size.
Your SHG looks very impressive!!
Merrill55
Oh, I get it now!
Oh, I get it now!
Post by Merrill55 » Wed Dec 14, 2016 10:01 am
Thank you Ken,
Even if 451MB,I got an error in SliM.
I do'nt understand this error message.
Merrill55
Oh, I get it now!
Oh, I get it now!
Post by Merrill55 » Wed Dec 14, 2016 1:04 pm
OK !
VDab-> SliM I could make 1 frame!
How can I save this frame?
I'm a beginner in this procedure.
Merrill55
Oh, I get it now!
Oh, I get it now!
Post by Merrill55 » Wed Dec 14, 2016 1:23 pm
I found out the new one in same old.avi folder.
I should become aware of saving method. So sorry!
highfnum
Post by highfnum » Wed Dec 14, 2016 1:24 pm
SliM auto creates a TIFF file with same name as avi that went in - should be in same directory
Merrill55
Oh, I get it now!
Oh, I get it now!
Post by Merrill55 » Wed Dec 14, 2016 1:40 pm
Thank you highfnum.
I waiting for next clear morning.
highfnum
Post by highfnum » Wed Dec 14, 2016 3:17 pm
I saw you are using binoviewer in optical path -- what is it for?
Merrill55
Oh, I get it now!
Oh, I get it now!
Post by Merrill55 » Thu Dec 15, 2016 4:39 am
The binocular device is used to facilitate optical axis adjustment.
In order to use it as a spectrohelioscope, a littrow type optical system is not appropriate.
Off-axis light causes distortion.
Post by Merlin66 » Thu Dec 15, 2016 5:26 am
Toshio,
I have a similar set-up using a 100/1300 scope an a 70/900 Littrow 1200 l/m grating spectrograph.
The only distortion is the slant of the absorption lines within the spectrum which is easily fixed. A similar system is used by Fulvio Mete (http://www.lightfrominfinity.org/Hirss% ... scopio.htm)
Do you have other distortions??
Merrill55
Oh, I get it now!
Oh, I get it now!
Post by Merrill55 » Thu Dec 15, 2016 6:00 am
No, I have not other distortion.
My aim is to make a telescope to observe the sun by my eye.
But I have not succeeded yet.
Post by Merlin66 » Thu Dec 15, 2016 6:13 am
Toshio,
Understood.
Which 20 micron entrance slit do you use - Thorlabs?
A SHS needs vibrating slits or Anderson prisms - see Fred's book (files area of the Yahoo Astronomical Spectroscopy group) or Chapter 11 of "Imaging Sunlight" (http://www.springer.com/gp/book/9783319248721)
Merrill55
Oh, I get it now!
Oh, I get it now!
Post by Merrill55 » Thu Dec 15, 2016 6:39 am
My Hale vibrating slit made by razor blade.
H-alpha photo by old SHS is as follow.
Today's solar surface
Post by Merlin66 » Thu Dec 15, 2016 6:57 am
Toshio,
Well done.
It looks like you understand the design requirements.
Look forward to seeing your future results.
Has thanked: 1063 times
Been thanked: 363 times
Post by Montana » Thu Dec 15, 2016 9:56 am
Wow! fabulous image :bow :hamster:
highfnum
Post by highfnum » Thu Dec 15, 2016 10:08 am
that photo with SHS how was that taken
that's NOT using a merge program - correct?
Merrill55
Oh, I get it now!
Oh, I get it now!
Post by Merrill55 » Thu Dec 15, 2016 1:12 pm
My old SHS is as follows,
I need not use 'merge' soft.
last year's h-alpha photo
synthesizer folded Hale slits
Over view
Over view
My old spectrohelioscope design
highfnum
Post by highfnum » Thu Dec 15, 2016 1:46 pm
Wow impressive!
So the 2 slits spin around I assume
To build image?
Kind of like mr Hale did way back when
Post by Merlin66 » Thu Dec 15, 2016 2:34 pm
John,
The small pin on the motor in the slot "oscillates" the two slit plates back and forth. See "Imaging Sunlight", sect 11.2.1 for more details.
Post by Merlin66 » Thu Dec 15, 2016 2:38 pm
Toshio,
Very nice results from a very nice SHS. Impressive!
Well done.
