Geomagnetic unrest 18th Jan
Post by Carbon60 » Thu Jan 19, 2017 6:52 am
Hi all,
There's yet another large coronal hole spewing solar wind earthward, creating beautiful aurora and moving the needles on magnetometers globally.
Here are my data from Preston, UK, which clearly show an increasing degree of geomagnetic unrest through the day and a significant upswing mid afternoon when Earth entered deeper into the fast flowing plasma.
20170118_G1_Coronal Hole.jpg (152.88 KiB) Viewed 1246 times
20170118_G1_Coronal Hole_Rate of Change.jpg (113.86 KiB) Viewed 1246 times
The next few days should bring good viewing for aurora watchers.
Thanks for looking.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
Re: Geomagnetic unrest 18th Jan
Post by Montana » Thu Jan 19, 2017 8:11 am
Excellent data Stu :hamster: pity the weather is so bad for viewing ;)
Did you see the Spaceweather data showing the ocillations every 2 minutes from Norway? it would be interesting to compare your oscilallation rate to theirs to see if there is any difference between here and there.
Post by marktownley » Thu Jan 19, 2017 9:13 am
Good data again Stu!
Would be great if you could stream this graphs 'live' on the web ;)
Post by Carbon60 » Thu Jan 19, 2017 6:01 pm
Thanks Alexandra/Mark,
I run this thing 24/7, but occasionally shut down for a spot of maintenance.......guess what, it was down at the critical time. I did, however, write to the solar physics department at Lancaster Uni with my previous data and the fine detailed structure was confirmed as real, coinciding with their data, so at least that's something. In any case, there isn't necessarily good agreement between data from disparate magnetic stations.
I have often thought of streaming my data and might do this someday.
Cheers
NEQ6 Pro-mount
Geremia Forino
Post by Geremia Forino » Thu Jan 19, 2017 7:07 pm
I am increasingly convinced that this has something to do with our earthquakes, since yesterday that the center Italy started shaking again.
Looks like the magnetic event attract or reject the center pole of the Earth and that crumbles the weakest parts of the earth's crust
Post by Carbon60 » Fri Jan 20, 2017 6:34 am
An interesting theory, Geremia, but statistical evidence suggests that there is no causal link.
http://www.thesuntoday.org/solar-facts/ ... rthquakes/
So sorry to see on the news the effects of the earthquakes.
NEQ6 Pro-mount
Geremia Forino
Post by Geremia Forino » Fri Jan 20, 2017 7:59 am
Thanks for the interesting link Stu and thanks for your measurements that, I have to follow more carefully, I'm sure this is the third coincidence, maibe the Geomagnetic effect are proportional to a specific position of the Earth, maibe the weakest part or maibe this is the right time i have to believe in the theory of the casualty :-)
highfnum
Post by highfnum » Sat Jan 21, 2017 12:19 pm
nice work as usual
I collected some data here in NY have not processed yet
