Page 1 of 1
Solar wind sparks geomagnetic storms
Posted: Tue Mar 28, 2017 5:37 am
by Carbon60
A large coronal hole facing Earth is spewing high speed, southerly polarised solar wind, sparking aurora and moving magnetometer needles around the globe.
- 20170327_Coronal Hole.jpg (109.33 KiB) Viewed 4780 times
The southerly magnetic orientation within the plasma is making this particularly potent, allowing strong magnetic connection with Earth's magnetic field, generating a strong geomagnetic response.
Thanks for looking.
Re: Solar wind sparks geomagnetic storms
Posted: Tue Mar 28, 2017 8:38 am
by carlosjackal
Good stuff Stu! This was my first chance to test the temperature controlled version. Here's a raw data shot they look very agreeable.
Carl
- IMG_20170327_212522.jpg (2.24 MiB) Viewed 4775 times
Posted: Tue Mar 28, 2017 8:59 pm
by marktownley
Good data there gents!
Posted: Wed Mar 29, 2017 5:50 am
by Carbon60
Thanks, Mark.
Carl, it looks like you're in business! Do you require the excel spreadsheet I've developed to scale and plot the data? Please send me a PM if you do.
Good work.
Posted: Wed Mar 29, 2017 8:27 am
by carlosjackal
Thanks Mark!
Stu yes the temperature control is a huge difference. The Eco is keeping to within 0.1 deg and working great!
I got the spreadsheets through PM last time so have them but i didn't get the instructions. The setup guide would be great. Just a note for some reason i cant reply on the PM system.
Thanks again.
Carl
Posted: Wed Mar 29, 2017 11:28 am
by Montana
Great data and they look very comparable too
I got red alerts the other night, it was cloudy and I thought of you, at least you don't require clear skies
Posted: Thu Mar 30, 2017 5:43 am
by Carbon60
Absolutely, Alexandra.....Clouds are no problem
Carl, I'll aim to send you some instructions, but basically copy and paste your CSV data from your captured Spectrum Lab files into column 'A' and then ensure that the charts are set to plot from the start and end of the columns of calculated output data.
Regards
Stuart
Posted: Thu Mar 30, 2017 10:23 pm
by carlosjackal
Thanks Alexandra looks to be working well.
That would be great Stuff just need to know how to capture the CSV data as i just have it running live as such.
Cheers Carl
Posted: Sat Apr 01, 2017 6:38 am
by Carbon60
Hi Carl,
Setting up sampling rate:
The first task is to set (or check) the sampling rate.
Under SpectrumLab OPTIONS select 'spectrum display settings' and then under the 'spectrum (1) tab ensure that the sampling rate is set to 150 seconds. This provides sufficient resolution for daily data capture.
- Setting sampling rate.jpg (214.07 KiB) Viewed 4716 times
Setting up data capture:
Back on the main screen, select FILE and tick 'Export Calculated Data (Continuously)'.
Under the File Contents tab ensure that the column separator value is set to '9' and that the number of columns is set to '2'
Set the column titles as shown (time and frequency) and set the values and format as shown.
- Setting exported data format.png (47.13 KiB) Viewed 4716 times
Under the file activation tab set the destination folder to which the data will be saved and tick 'active'. Data will then be captured at the rate set above (150 seconds) and saved in the designated folder.
CSV data:
Your captured data should open as a CSV text file, similar in format to this.....
- CSV file.jpg (117.11 KiB) Viewed 4716 times
You can then simply highlight the values (not the headings), copy and paste into cell 'A8' of the Excel spread sheet. The entire column should then automatically populate with the data and the spreadsheet will generate the output data. Don't forget to set cells F3 and F4 with the 'null' frequency (the frequency at which the output from the detector drops to zero) and the 'set frequency' (the frequency set on the detector LCD screen to give an output pitch of 3-4 kHz). Keep cell H4 (filter) set at 8 for now. This can be changed to higher or lower values to modify the output depending on the quality of the input (i.e. noise spikes). Higher numbers here have less of a filtering effect on the data.
Cells K3 and K4 allow you to scale the charts according to your closest 'INTERMAGNET' station if you want to. Simply go online to
http://www.intermagnet.org/data-donnee/dataplot-eng.php, select a station closest to your location and plot the relevant data. Take note of the max and min nT values and use these to set cells K4 and K3 accordingly.
The following screen shots just tell you about setting up the charts, which you might already be familiar with.
- Chart1.jpg (491.66 KiB) Viewed 4716 times
- Chart2.jpg (508.66 KiB) Viewed 4716 times
- Chart3.jpg (563.99 KiB) Viewed 4716 times
I hope this helps.
Posted: Sat Apr 01, 2017 11:24 am
by carlosjackal
That is fantastic Stu! Thanks for taking the time to do it. I well have a go at this later today.
Cheers Carl
Posted: Sat Apr 01, 2017 1:35 pm
by highfnum
I got some data also from out here in the west
Posted: Sun Apr 02, 2017 5:19 am
by Carbon60
Good luck, Carl. I'm sure it will work out.
Looking forward to seeing your data from out west, John.
