Spectroheliograms 19Jun2017
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Post by p_zetner »
Greetings Everyone.
Back in action with my spectroheliograph.
Here are two "test shots" with my reconfigured SHG using the Celestron NexStar 4SE as telescope. Two big advantages of this scope: a motorized focuser and less glass (than my previous Astro-Rubinar lens) to give better UV transmission.
A picture of the instrument:
SHG Jun2017.png (780.95 KiB) Viewed 4430 times
Pretty happy with the new arrangement so far. Focusing the Astro-Rubinar telephoto was a pain.
I was able to take advantage of cooperative weather for an extended, multi-wavelength imaging session today (20 Jun).
Hope to process and post the new images soon.
Peter.
Has thanked: 173 times
Been thanked: 615 times
Re: Spectroheliograms 19Jun2017
Wooh.......
That's a very difficult balancing job!!!
Great results, look forward to seeing more.
(No ERF?)
Has thanked: 20448 times
Been thanked: 10254 times
I always enjoy seeing your work Peter! Great stuff!
p_zetner
Post by p_zetner »
Thanks Mark and Ken.
Ken, here's another view of the SHG with more of the construction details visible. The entire instrument weighs about 12kg. It's not terribly more unwieldy than the previous version but I can notice flexure when viewing afternoon Sun as opposed to morning Sun. I'm trying to think of an improved mounting arrangement for the Celestron. At the moment, you can see the aluminum bar and rod used to support its weight. You can also see the counterweight on sliding bar which I use to balance (in dec).
I don't use an ERF on the Celestron. From what I can tell, apart from the corrector plate, there are only reflective optics. The Astro-Rubinar had cemented achromats near the focus.
Peter.
highfnum
Has thanked: 57 times
Been thanked: 1190 times
Post by highfnum »
wow looks complicated but works well
nice to see others doing this
Phil Rousselle
Been thanked: 7 times
Post by Phil Rousselle »
Hi Peter, your SHG is very long but works fine. K3 image has a very good bandwidth and contrast
Phil
Has thanked: 8420 times
Been thanked: 8173 times
Very nice SHG images, Peter. Always good to see your work.
Maybe mount everything rigidly in a lightweight wooden box.... It would take away some of the beauty of this arrangement, but might make for a more stable instrument. It looks impressive, but precarious :)
Stu,
That's what I did with the 100mm Littrow SHG, see:
viewtopic.php?f=8&t=20682
p_zetner
Post by p_zetner »
Thank you all for your comments.
Phil: You should know that it was your work that motivated me to pursue "spectroheliography" in the first place! Your spectroheliograms are inspirational and your website very informative. I encourage all aspiring spectroheliographers to read through it. Thanks for the visit.
Stu: Your comments are always welcome. The suggestion of the wooden support box is good (see Phil Rousselle's original design!) but, aside from experimenting with some minor tweaks, I'm reasonably happy with my configuration at the moment. I'm planning a much larger instrument which will necessarily be housed in a box of some sort and fed sunlight through a coelostat ... a long term project!
Peter.
Has thanked: 17672 times
Been thanked: 8795 times
Wow, the images are lovely and a great set up too :bow :hamster:
