Recent Digital SHG
Recent Digital SHG
Trial H-alpha photo in 2018_07_14_07:12(JST) by Digital Spectro_Helio_Graph.
- 07_12_27_000_CUP_RG_C.jpg (2.79 MiB) Viewed 5373 times
- Has thanked: 173 times
- Been thanked: 615 times
Re: Recent Digital SHG
More detail on the SHG system, please!!!
Telescope is Diameter 80mm and Focal length 910mm of acromatic lens.
Collimator, Camera lens is Diameter 70mm and Focal length 700mm of achromatic lens.
Slit width is about 20 micron.
I used 2* barlow lens. Telescope's effective focal length is about 1800mm.
CCd camera is ASI1600MM.
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Very nice imaging, especially using a telescope focal length of 1800mm. Your seeing conditions must have been relatively stable.
- Has thanked: 57 times
- Been thanked: 1189 times
Yes, definitely a very good SGH image!!
I'd appreciate seeing an image of your set-up.......
- DSobserver
- Been thanked: 19 times
Thank you.
My SHG has low contrast and I have an optical axis is not to match definitely.
For the good capture, good seeing is necessary.
Including a background, as for the good seeing of 3 minutes, it is rare.
Birds and clouds, an airplane, the strong wind are enemies.
I am improving it now to extend a collimator lens focus.
- H-Beta
- 07_38_50_001_H-beta_RG.jpg (1.22 MiB) Viewed 5270 times
- H-Alpha
- 06_37_03_000.jpg (1022.72 KiB) Viewed 5270 times
- H-Alpha
- 06_50_09_000_CUP.jpg (2.14 MiB) Viewed 5270 times
- Has thanked: 20424 times
- Been thanked: 10243 times
Nice captures!
- Spectral Joe
If these are trials then you are definitely on the right track! Excellent for initial efforts. Definitely some stray light, have you trapped the ghost images of the slit?
Not blind yet, either!
Thank you Joe.
Not yet.
I blocked almost stray light carefully.
I suppose it owes the rear surface of collimator lens.
For h-alpha light,I use a red filter on the front of telescope lens .
I will use the block bead for strong gohst.
Not yet.
- Has thanked: 17666 times
- Been thanked: 8787 times
